    Restart ES doesn't work (pc x64)
    Testers's corner
    restart doesnt x64
    2161
    • polhallen
      polhallen last edited by
      Hello, I'd like report that from browser, "restart es" doesn't work: only stop ES but doesn't restart.
        Zing Global moderator Translator @polhallen last edited by
        @polhallen It may be a problem in your installation, to check if this is the case, you would need to do a new installation... But, soon, version 7.0 of Recalbox will be released, which will require a clean installation, maybe you prefer to wait...
        • polhallen
          Hi Zing, thanks for you reply 🙂
          I tried with 2 different hard drive, two times with x86 e x64 but I've same error 😕
          Pol
            @polhallen It’s a problem I’ve never seen happen, can you give more details?
            What's your version of Recalbox (say the version, don't say "the last one")?
            Did you build your Recalbox yourself, or did you download a ready-made image from the internet?
            Why do you need to restart ES?
            Have you tried, after stopping ES, updating your browser, and then trying to start ES?
            • polhallen
              Have you ever used pc version? The problem happens only with that version... x86 and x64 versions.
              I downloaded 6.1.1 version from here: https://recalbox-releases.s3.nl-ams.scw.cloud/stable/v2/upgrade/x86_64/recalbox-x86_64.img.xz?source=install
              put a hard disk to usb case and using etcher 1.5.108 (https://www.balena.io/etcher/) to write img file to disk
              next I putted hard drive on pc and started it
              First boot everything works, when I reboot and startup again I've the problem.
              I tried with many browser (firefox 80.0.0.1, brave 1.13.82, chromium 83.0.x)
              I using "restart ES" for testing purpose.
              thanks for help
              Pol
                @polhallen
                Yes, a few times, but, I already used it, and to be honest I didn't need to restart ES in these situations, but I also didn't see anything reported here on the forum until now.
                Your system installation process is apparently correct, but I need to ask a detail:
                You claim that the first boot works, and after restarting, it no longer works... Is the system creating the SHARE partition correctly on this first boot? Did you transfer your ROMS to Recalbox, restart, and were they still there?
                Are you connected to the network via cable or Wi-Fi?
                Have you tested on another computer?
