    USB Controller not working in games
    GamePad/GPIO/USB encoder
    usb
    • PAMOON
      PAMOON last edited by
      After months of working fine, I went to the controller settings and attempted to re-confirm the usb settings as I noticed the USB controller wasnt working right in some games. Then no games would work with the controller at all.
        Zing Global moderator Translator @PAMOON last edited by
        @PAMOON You didn't give enough information, I just know that you have a problem with the joystick. To get help, detail as much information as possible:
        • Your hardware
        • Your version of Recalbox (say the version number, don't say "the last one")
        • Did you build the system yourself, or are you using a ready-made image from the internet, or did you buy the system already configured?
        • Are you sure that the joystick is not the problem?
        • Before it worked perfectly? What happened that stopped working, did you change anything else?
        • Have you tested with another joystick?
