    Menu Resolution
    • Drizzt
      Drizzt last edited by
      Hi, is there a way to set a custom resolution for the Recalbox menu?
      I'm using a tv that just so happens to be 1804x1014.
      Might be a good idea to add that in menu options for a later version. ^.^
      • airdream
        airdream Theme moderator last edited by airdream
        you can change recalbox menu resolution between few modes
        You just have to edit recalbox.conf file, this line below only.
        ;system.es.videomode=CEA 4 HDMI
        it will be (for exemple)
        system.es.videomode=CEA 2 HDMI
        You have to delete " ; " on the begening of this line also
        and
        You can change " 4 " by an other value (2 for exemple), take care to not use so high resolution on RPI, or it will overheat and slowdown games (under 1080)
        Value between 1 and 65
        (65 is custom)
        1	VGA (640x480)	60Hz	4:3
        2	480p	60Hz	4:3
        3	480p	60Hz	16:9
        4	720p	60Hz	16:9
        5	1080i	60Hz	16:9
        6	480i	60Hz	4:3
        7	480i	60Hz	16:9
        8	240p	60Hz	4:3
        9	240p	60Hz	16:9
        10	480i	60Hz	4:3	pixel quadrupling
        11	480i	60Hz	16:9	pixel quadrupling
        12	240p	60Hz	4:3	pixel quadrupling
        13	240p	60Hz	16:9	pixel quadrupling
        14	480p	60Hz	4:3	pixel doubling
        15	480p	60Hz	16:9	pixel doubling
        16	1080p	60Hz	16:9
        17	576p	50Hz	4:3
        18	576p	50Hz	16:9
        19	720p	50Hz	16:9
        20	1080i	50Hz	16:9
        21	576i	50Hz	4:3
        22	576i	50Hz	16:9
        23	288p	50Hz	4:3
        24	288p	50Hz	16:9
        25	576i	50Hz	4:3	pixel quadrupling
        26	576i	50Hz	16:9	pixel quadrupling
        27	288p	50Hz	4:3	pixel quadrupling
        28	288p	50Hz	16:9	pixel quadrupling
        29	576p	50Hz	4:3	pixel doubling
        30	576p	50Hz	16:9	pixel doubling
        31	1080p	50Hz	16:9
        32	1080p	24Hz	16:9
        33	1080p	25Hz	16:9
        34	1080p	30Hz	16:9
        35	480p	60Hz	4:3	pixel quadrupling
        36	480p	60Hz	16:9	pixel quadrupling
        37	576p	50Hz	4:3	pixel quadrupling
        38	576p	50Hz	16:9	pixel quadrupling
        39	1080i	50Hz	16:9	reduced blanking
        40	1080i	100Hz	16:9
        41	720p	100Hz	16:9
        42	576p	100Hz	4:3
        43	576p	100Hz	16:9
        44	576i	100Hz	4:3
        45	576i	100Hz	16:9
        46	1080i	120Hz	16:9
        47	720p	120Hz	16:9
        48	480p	120Hz	4:3
        49	480p	120Hz	16:9
        50	480i	120Hz	4:3
        51	480i	120Hz	16:9
        52	576p	200Hz	4:3
        53	576p	200Hz	16:9
        54	576i	200Hz	4:3
        55	576i	200Hz	16:9
        56	480p	240Hz	4:3
        57	480p	240Hz	16:9
        58	480i	240Hz	4:3
        59	480i	240Hz	16:9
        60	720p	24Hz	16:9
        61	720p	25Hz	16:9
        62	720p	30Hz	16:9
        63	1080p	120Hz	16:9
        64	1080p	100Hz	16:9
        65	Custom
        https://github.com/recalbox/recalbox-os/wiki/Video-configuration-detailled-(EN)
        https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
