    Impossible de lancer un jeu
    650
    • MichelD
      MichelD last edited by acris
      bonjour,
      J'ai un raspberry pi2 B avec la dernière version de RecalBox fraîchement réinstallée et pourtant aucun jeu ne se lance plus.
      J'ai remis sonic megadrive qui fonctionnait parfaitement avant (il y a quelques mois) et lorsque je le lance, un écran noir s'affiche puis retour au menu Recalbox.
      Voici le contenu du fichier es_launch_stderr.log trouvé dans system/logs:
      Traceback (most recent call last):
        File "usr/lib/python2.7/site-packages/configgen/emulatorlauncher.py", line 409, in <module>
          exitcode, waitNeeded = main(args)
        File "usr/lib/python2.7/site-packages/configgen/emulatorlauncher.py", line 300, in main
          command = getGenerator(system.config['emulator']).generate(system, arguments.rom, playersControllers, arguments.demo, recalboxSettings)
        File "/usr/lib/python2.7/site-packages/configgen/generators/libretro/libretroGenerator.py", line 93, in generate
          newConfigFileName, overrideFileName, commandArgs = self.createConfigurationFile(system, playersControllers, rom, demo, recalboxSettings)
        File "/usr/lib/python2.7/site-packages/configgen/generators/libretro/libretroGenerator.py", line 80, in createConfigurationFile
          retroarchConfig, retroarchOverrides = configuration.createRetroarchConfiguration()
        File "/usr/lib/python2.7/site-packages/configgen/generators/libretro/libretroConfigurations.py", line 97, in createRetroarchConfiguration
          controllers.fillControllersConfiguration()
        File "/usr/lib/python2.7/site-packages/configgen/generators/libretro/libretroControllers.py", line 118, in fillControllersConfiguration
          self.buildController(self.controllers[controller], controller)
        File "/usr/lib/python2.7/site-packages/configgen/generators/libretro/libretroControllers.py", line 253, in buildController
          settings.setOption("input_%s%s" % (specialvalue, self.typetoname[inp.type]), self.getConfigValue(inp))
        File "/usr/lib/python2.7/site-packages/configgen/generators/libretro/libretroControllers.py", line 180, in getConfigValue
          return 'h' + inp.id + LibretroControllers.hatstoname[inp.value]
      KeyError: '-8'
      Merci pour votre aide
        Bonjour @MichelD
        tu nous donnes aucunes informations sur ta précédente version ni si tu étais sur support amovible.
        as tu reconfiguré ta manette dans le menu ES même si elle fonctionne out of box.
        il est possible que ce soit tout simplement ta microsd qui ait un problème.
        as tu testé les jeux démos avant de transférer la rom , en espérant que tu aies uniquement transféré ça.
        MichelD 1 Reply Last reply Reply Quote 0
        • MichelD
          MichelD @acris last edited by
          bonjour @acris ,
          Une carte micro sd se trouve dans le raspberry.
          Dans les faits, recalbox fonctionnait parfaitement vers Noël il me semble et pendant les vacances de février je resors le raspberry et les jeux ne se lançaient plus (sans aucune intervention entre 2).
          J'ai donc reinstallé la dernière version de recalbox et reconfiguré les manettes comme d'habitude.
          J'ai parcouru tous les jeux par défaut et 1 seul veut bien se lancer : Flower sur Commodore 600.
          J'ai transféré uniquement la rom de Sonic (Megadrive) et ce jeu ne fonctionne plus.
          Ton hypothèse de carte SD HS est possible. Je vais essayer de mettre la main sur une autre carte micro SD et réinstaller recalbox. Je tiendrai informé le forum du résultat car cela peut aider certains.
          Aurais-tu d'autres hypothèses ?
            @MichelD
            as tu transféré uniquement les roms, ou les gamelist.xml aussi ?
            si oui il se peut que ce soit les gamelist.xml pour les systèmes.
            tu n'as pas transféré le dossier systems ?
            • MichelD
              @acris
              Je viens d'installer recalbox sur une nouvelle carte micro sd, puis j'ai reconfiguré 1 manette. Le même problème persiste, seul le jeur Flower se lance 😞
              Problème d'alimentation pas assez puissante (2.4A) ?
              J'ai testé les 2 carte micro sd en lecture et elles atteignent 20Mb/s.
                il faut minimum une alimentation 2.5A avec un raspberry pi 3b+ voir 3A pour être bien.
                as tu un éclair jaune en haut à droite ?
                tu as transféré des roms ou tester uniquement les roms démos ?
                tu as retéléchargé l'archive aussi pour supprimer une éventuellement problème de téléchargement.
                Je remet les étapes ici :
                • télécharger l'archive recalbox
                • décompresser l'archive.
                • télécharger ou mettre à jour etcher.
                • executer etcher en mode administrateur via le clic droit de la souris.
                • etcher formate lui meme le microsd avant le flash, inutile de le faire avant.
                • insérer la microsd dans recalbox.
                • booter
                • configurer uniquement une manette et tester les jeux vidéos démos présents.
                si tout est ok
                • Formater la clé usb en exFAT.
                • Brancher la clé usb sur le rpi
                • booter
                • changer le stockage interne vers la clé usb.
                • rebooter.
                • MichelD
                  Merci pour les étapes @acris
                  J'ai tout bien fait comme avant, quand ça marchait.
                  J'ai un rpi 2 qui demande moins de puissance normalement.
                  J'ai commandé une nouvelle alim de 3A.
                  Je testerai avec lorsque je la recevrai.
                  A suivre, je vous tiens au courant.
                  merci
                    @MichelD
                    dernières possibilités :
                    • adaptateur microsd défectueux
                    • cardreader de ton pc défectueux.
                    • remplacer l'adaptateur par un autre.
                    • mettre à jour les pilotes du cardreader.
                    et ultime le port microsd de ton rpi2 qui a un soucis...
                    • MichelD
                      J'ai reçu la nouvelle alim 3A.
                      J'ai préparé une nouvelle carte SD.
                      Mais les jeux continuent à ne pas se lancer.
                      Je ne sais plus quoi faire avec recalbox sur RPI...
                      Si vous avez d'autres pistes, je suis preneur. Il doit bien y avoir un fichier de log qui trace l'erreur...
                        @MichelD tu as quoi comme manette ?
                        teste uniquement les jeux démos
                        ya des logs dans /systems/logs/
                        • MichelD
                          j'ai testé uniquement avec les jeux par défaut biensûr.
                          Mes manettes sont des Speedlink Strike2. Elles étaient compatible jusqu'à Noël.
                          • MichelD
                            @acris bonjour
                            Voici le contenu du fichier es_launch_stderr.log après lancement en échec du jeu Amstrad Joe contre les pharaons
                            merci
                            KeyError: '-8'
                            • MichelD
                              on retrouve dans cette log
                              • playersControllers
                              • libretoControllers.py
                              Mes manettes seraient devenues plus compatibles ?
                              • MichelD
                                Afin de clôturer ce sujet, je vous informe que tout remarche correctement avec RecalBox V7.
                                  @MichelD
                                  as tu identifié le problème ?
                                  100.8k
