    Solved Kernel Panic on hp usff
    kernel panic usff
    • mrMike
      mrMike last edited by mrMike
      Hi I have just install using etcher new 6.1.1 recallbox os on my hp USFF and i have kernel panic screen - Attempted to kill Int.
      previous version of Recalbox worked like a charm on that computer. i see boot pratition under windows. can i edit anything to make it boot?
      thanks!
      mrMike 1 Reply Last reply Reply Quote 0
      • mrMike
        mrMike @mrMike last edited by
        @mrMike
        Hi To anyone with the same issue. i had to upgrade BIOS on my hp that solved the issue. thanks
        robertcamilo23 1 Reply Last reply Reply Quote 0
          @mrMike
          thanks for your feedback.
          • robertcamilo23
            robertcamilo23 @mrMike last edited by
            @mrMike Hi, which BIOS version do you had before the issue, and what is your current BIOS version?
