    Solved Kodi with gamepads
    MediaCenter & Dualboot
    kodi gamepads
    • Tosnic
      Tosnic last edited by
      Hi guys.
      I am mainly using the Kodi part of Recalbox, especially the picture viewer. Using gamepads as input device, I noticed that some functions do not work properly. E.g., the Xbox 360 (wired) controller can not navigate up or down with the D-pad! Left and right are working. This could probably be solved using the keymap editor.
      But my main problem is with the Dualshock3 controller: when I zoom into a picture and want to scroll around inside the zoomed picture, all directions of the left thumbstick go either down or right, but not up nor left. I even viewed the keymap file, where the according action (called "AnalogMove") is simply assigned to the "left thumbstick". Therefore, I have no means of changing this behavior. Inside the emulation part of recalbox the left thumbstick is recognized properly: I can move in all 4 directions in Doom and Zelda.
      I had a LibreElec installation before with the current version of Kodi. This had slightly different key layout (zoom with D-pad), but the scrolling of zoomed-in pictures worked as it should using the left thumbstick of the Dualshock3 controller.
      Hardware: Raspberry Pi 3B+, original Sony Dualshock3 gamepad (via BT)
      Recalbox version: 6.11 Dragonblaze
      How can I fix this issue?
      Tosnic 1 Reply Last reply Reply Quote 0
      • Tosnic
        Tosnic @Tosnic last edited by
        This issue has been resolved in Recalbox v7 😄
