    RESIDENT EVIL 2 EMULATION - Various Problems
    Emulator Arcade/PC/Console
    resident evil various
    • MrMaceta
      MrMaceta last edited by
      Hi, y got a rrp3 and im not really shure whats my recalbox version (the manager says its 2.2.3), tried 3 RE2 versions , every one of them got 3 files two .bin (track 1 and track 2) and a .cue
      Im using a "prebuild" version that i bought online.
      Every other thing works great, only whit RE2 i got these problems.(and im guessing that every game that have the same "multi track" stuff, ive only tried RE2).
      I couldn't use de psx2psp method to "gather" them, and i cant even load any of the .cue flies. Its been 3 days since i started, and i cant make it work, any tips?, i've readed every coment in a thread on RE2 and havent find any solution.
      Thanks!
      • joinski
        joinski last edited by joinski
        google "PSX multi track bin to single bin" and you will find a solution 😉
        this is what i found on the quick:
        https://www.youtube.com/watch?v=McrNQPc07RM
        https://www.youtube.com/watch?v=c63KTNwZ41E
        MrMaceta 1 Reply Last reply Reply Quote 0
          Scavy Global moderator @MrMaceta last edited by Scavy
          @MrMaceta said in RESIDENT EVIL 2 EMULATION - Various Problems:
          @joinski
          If i'm right, RE2 game is not a 2 discs game but a game with 2 discs separataly : i mean there is one disc where you play with Claire Redfield and one where you play with Leon Kennedy. So... You can't create an .pbp eboot using psx2psp !
          I've got the game on my PSX roms, both of the discs runs separataly (and they work well). But it's a fact, the game is scraped twice ^^
          • MrMaceta
            MrMaceta @joinski last edited by
            @joinski said in RESIDENT EVIL 2 EMULATION - Various Problems:
            I love you. I did try, but, key words where the problem in my search!, tnx. Gonna try that
