    Solved neo-geo and mame
    Emulator Arcade/PC/Console
    neo-geo mame
    • burts_19
      burts_19 last edited by
      Both neo-geo and mame were running fine with sound. After scraping with universal XML scraper there was no sound and slow. Removed roms, gamefiles and images - added the roms back on and still the same, loading and playable but no sound and slow. Any advice please?
      running recalbox 6.1.1 on odroid xu4.
        Hello
        Emulationstation Menu > sound options > enable other option not auto , and try.
        burts_19 1 Reply Last reply Reply Quote 0
          Scavy Global moderator @burts_19 last edited by
          @burts_19 said in neo-geo and mame:
          Nothing to do with the sonund, but XML is out of date.
          You'd better use skraper : http://skraper.net/
          or ARRM : http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
          • burts_19
            burts_19 @acris last edited by
            @acris said in neo-geo and mame:
            Hello
            thanks - checked that and already using the 'non-auto option'.
            • burts_19
              I formatted my SD card, flashed recalbox onto it again, added my roms (without scraped images), and neo-geo is working again fine.
              Is there anyway scraping the images caused this? It seemed to change the metadata - it's just I'm fearful of scraping for images now in case it happens again.
              I realise this is a pretty lame/vague problem - apologies.
