    DosBox - Dungeons Keeper
    Emulator Arcade/PC/Console
    dosbox dungeons keeper
    6549
    • Fefo81
      Fefo81 last edited by Fefo81
      Hi guys,
      I need your help for using Dungeons Keeper with DosBox (Recalbox Dragonblaze on RP3B+).
      I am a novice about Dos so reading the guide ‘How to use DOSBox to Emulate DOS games‘ didn’t clarify all.
      I have already done an experiment installing The Settlers 2 and it worked well.
      I followed this good tutorial on YouTube
      https://youtu.be/rTYBj_WOnnk
      However the process for installing The Settlers 2 is different than for Dungeons Keeper because in this case there is a Bin/cue file in the folder. I attached the picture with the files I have in my dungkeep.pc
      Can anyone help me with that? I need really basic instructions because many things clear for you are not for me...
      Thank you very much
        Zing Global moderator Translator @Fefo81 last edited by
        @Fefo81 Read this:
        https://github.com/recalbox/recalbox-os/wiki/How-to-use-DOSBox-to-emulate-DOS-games
        • Fefo81
          Hi @Zing thank you for your reply. I have already read the link you posted but it’s not completely clear to me.
          I have tried different things but it does not find the cd (I have bin and cue file).
          Imgmount d .\cd\KDDISK~1.cue -t iso
          Fefo81 1 Reply Last reply Reply Quote 0
          • Fefo81
            Fefo81 @Fefo81 last edited by
            • gabooks
              gabooks last edited by
              I have the same question, thanks for reply
                Zing Global moderator Translator @Fefo81 last edited by Zing
                @Fefo81 Let me better understand the situation (I don't speak English perfectly): the files in the print that you showed in the post, are inside a .bin file, right?
                I don't have this game, nor another game in this format, but, I can recommend:
                1 - Which is probably the easiest: open the .bin file on a computer, and extract all the content, using programs such as daemon tools, or PowerIso, or any program that manipulates .ISO / .bin type CD images and others. After that, just follow the original DOSBOX user manual, which I sent the link to earlier.
                2 - Continue the way you are trying to do: read these links:
                https://www.dosbox.com/wiki/MOUNT#Mounting_a_CD_ROM_drive
                https://www.dosbox.com/wiki/IMGMOUNT
                From what I read in the manuals (I never tried):
                First of all, you need to mount the folder where the .bin file is, and as far as I understand Reccalbox already does this automatically.
                After that, you use the command you tried: "Imgmount" by opening the file as if it were in the main directory from which you just mounted the first command (which by its print, is not being recognized, according to manual, in linux the path is read with "/" instead of "", you can see how in your print the path that Recalbox mounted automatically).
                So, you need to enter the partition you mounted to the file above, in your case d:
                And finally, start the main .exe file.
                But, if your .cue / .bin is actually the game installation, when you do all of that, it will launch the installer, and create a new folder with the game "installed", and, to play, you will have that starts with the game's .exe, not the installation's .cue.
                Fefo81 2 Replies Last reply Reply Quote 0
                • Fefo81
                  Fefo81 @Zing last edited by
                  @Zing Thank you very much. I’ll try and I let you know.
                  • Fefo81
                    @Zing New update about this endeavour...
                    I mounted the game on daemon tools and then I copied and paste the game on the dos folder in recalbox.
                    Following the tutorial below that helped me to Previously install The Settlers 2, I added a file DOSBox.bat (inside setup.exe).
                    The setup started well. I fixed the audio. Then I clicked install in the game setup menu. The game (Dungeons Keeper) asked me the path giving me this line: c:\keeper
                    I completed the line in this way: c:\keeper/keeper.exe
                    This command triggered a video confirming installation of the game completed.
                    I open the dosbox.bat file and inside I change setup.exe to keeper.exe. However recalbox started loading the game but then it got back the menu.
                    So I changed dosbox.bat from keeper.exe to keeper/keeper.exe but the game got back to the menu
                    I changed dosbox.bat from keeper/keeper.exe to keeper\keeper.exe
                    In this case dosbox Black screen starts loading. It seems like it’s loading something but then it got back to recalbox menu.
                    Any help?
                    Thanks
                      @Fefo81 please make a print of the folder structure at this moment, and a print of the commands you are using, so that I can better understand.
                      • Smacaroni
                        Smacaroni last edited by
                        also add a line "pause" to the end of your dosbox.bat this will allow you to see the error that's causing the program to die.
                        • Fefo81
                          This is the picture of Dosbox... it said to install the cd... I don’t understand
                          This is the content of the folder dungkeep.pc
                          This is the content of the folder keeper
                          Thanks for your help
                            @Fefo81 WOW, it looks like you mistook half the information!
                            And checking out the prints, you told me one thing, but it's actually another.
                            Let's go to the beginning, you have these files in the dungkeep.pc folder: PRINT 1
                            I notice that there is a folder "cd", which has the file KDDISK ~ 1.cue (that you unzipped the corresponding .bin), and in fact, I understood that these files in the image above were inside a file. bin:
                            @Zing said in DosBox - Dungeons Keeper:
                            This is not the situation, so the idea is different:
                            Let's start from the first print you sent, in fact, it wasn't inside a .bin file, and you didn't need to unzip anything. Go back to that step, the way the game is in the first, and ignore the other steps you did.
                            In fact, you need to mount the file. cue that is in the cd folder, and after that, run the keeper.exe file that is in the main folder, you don't need to unzip anything, and you probably won't even need to install anything.
                            It looks something like this:
                            imgmount d "/recalbox/share/roms/dos/dungkeep.pc/cd/KDDISK~1.cue" -t iso
                            C:
                            keeper.exe
                            • Fefo81
                              @Zing first of all thank you very much for your help and for being so patient. As I said in the first post I’m a novice.
                              So If I understood correctly, I deleted the content of the folder extracted with daemon tools and I replaced in the dosbox folder the content I had at the beginning of the process. I also added the dosbox.bat and I wrote the commands you suggested me.
                              The game seemed to start but then appeared a screen asking for the cd.
                              Have I missed something?
                              Thanks
                                @Fefo81 Well, I'm helping without being sure (because I never did), but if we insist, at some point it will work!
                                If the executable starts, but does not recognize the CD, it indicates that the CD was not mounted correctly, do the following, try only the command:
                                pause
                                And take a print, it will give an error message in that command, we need to know what it is.
                                And, take a print of the contents of the "cd" folder.
                                Anticipating the result, check the correct name of the .cue file, I copied the name "KDDISK ~ 1.cue" from one of the prints you posted, but I didn't see what the correct name was. If that name is wrong, already try to put the correct name, in the command I quoted in the previous post and see what happens.
                                Everything indicates that either the path is wrong, or the name of the file, and therefore is not mounting the CD, which is necessary to run the game.
                                • nexusone13
                                  nexusone13 last edited by nexusone13
                                  Hi @Fefo81, @gabooks and @Zing
                                  I tried on my side and it's working with this configuration :
                                  Below you can see files and directories inside my "Dungeon Keeper.pc" directory
                                  Below the content of my "CD" directory
                                  And the content of "KEEPER" directory
                                  Here is my "dosbox.bat"
                                  You can remove the "pause". I put it here to check if CD image mount correctly
                                  Hope this can help you
                                  ARRM (Another Gamelist, Roms manager, and Scraper for Recalbox, Batocera, Retropie) : http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
                                  Wiki ARRM: http://www.jujuvincebros.fr/wiki/arrm/
                                  Discord: https://discord.gg/p7QsBTS
                                  Fefo81 1 Reply Last reply Reply Quote 1
                                  • Fefo81
                                    Fefo81 @nexusone13 last edited by Fefo81
                                    @nexusone13 @Zing Thank you very much for your effort.
                                    I tried this configurations moving my files coping your directories (names are the same). But I noticed I don’t have the file deeper.exe
                                    Unfortunately didn’t work.
                                    I noticed I have this file in my folder
                                    Below the content. Does it make any sense to you?
                                    • Fefo81
                                      nexusone13 1 Reply Last reply Reply Quote 0
                                      • nexusone13
                                        Deeper is useless, it's an extension of the main game.
                                        It's your configuration ?
                                        So could you make a screenshot of the content of the "CD" directory please
                                        • nexusone13
                                          nexusone13 @Fefo81 last edited by nexusone13
                                          @Fefo81 said in DosBox - Dungeons Keeper:
                                          @Fefo81 all this batch file are useless in our case.
                                          Be careful, if you renamed the CD image (.cue and .bin), you must open the .cue file with a text editor to modify the content corresponding to the .bin name
                                          • Fefo81
                                            @nexusone13 Exactly. This is my configuration.
                                            Below the content of the cd folder
                                            nexusone13 2 Replies Last reply Reply Quote 0
