    Matricom Bluetooth Gamepad
    GamePad/GPIO/USB encoder
    matricom bluetooth gamepad
    • substancev
      substancev last edited by
      Hello Recalbox Community!
      First and foremost, I hope all of you are staying safe and healthy.
      Since being bunkered in, I decided to check out recalbox. I loaded an image to find out that my bluetooth controller doesn't really work well with it. I am able to sync the controller and evtest shows response to buttons. However, in ES I am unable to configure the controller.
      From SSH I run /etc/init.d/S31emulationstation restart and when I press a button on the controller this is what I get:
      # /etc/init.d/S31emulationstation stop
      # /etc/init.d/S31emulationstation start
      # lvl0: 	System "favorites" is missing name, path, extension, or command!
      lo IP Address 127.0.0.1
      eth0 IP Address 192.168.1.77
      INFO: The key you just pressed is not recognized by SDL. To help get this fixed, please report this to the SDL mailing list <sdl@libsdl.org> EVDEV KeyCode 304
      INFO: The key you just pressed is not recognized by SDL. To help get this fixed, please report this to the SDL mailing list <sdl@libsdl.org> EVDEV KeyCode 307
      Is there anything I can do to resolve this?
      substancev 1 Reply Last reply Reply Quote 0
      • substancev
        substancev @substancev last edited by
        I have an RPi 3 b+.
        Controller is Matricom G-Pad BX
        Here is some additional information.
        # hcitool con
        Connections:
        	> ACL 58:6A:FB:B4:7D:94 handle 12 state 1 lm MASTER AUTH ENCRYPT
        # hcitool name 58:6A:FB:B4:7D:94
        Bluetooth Gamepad
        # bluetoothctl
        [NEW] Controller B8:27:EB:88:A6:2C BlueZ 5.39 [default]
        [NEW] Device 58:6A:FB:B4:7D:94 Bluetooth Gamepad
        [Bluetooth Gamepad]# info
        	Alias: Bluetooth Gamepad
        	Class: 0x002540
        	Icon: input-keyboard
        	Paired: yes
        	Trusted: yes
        	Blocked: no
        	Connected: yes
        	LegacyPairing: no
        	UUID: Serial Port               (00001101-0000-1000-8000-00805f9b34fb)
        	UUID: Human Interface Device... (00001124-0000-1000-8000-00805f9b34fb)
        	UUID: PnP Information           (00001200-0000-1000-8000-00805f9b34fb)
        	Modalias: usb:v1949p0402d0021
          OyyoDams Staff @substancev last edited by
          @substancev 17.12.02 is outdated. Please install latest version.
          • substancev
            substancev @OyyoDams last edited by
            @OyyoDams This occurred with Dragonblaze image i used. I am
            This is now running the latest img downloaded from your site and the above still applies
            • substancev
              @substancev For Matricom G-Pad BX (Bluetooth).. I added the following line to ~/udev/rules.d/99-bluetooth.rules:
              SUBSYSTEM=="input", ATTRS{name}=="Bluetooth Gamepad", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
              I got this line from a RetroPie setup. The menu system allows to add bluetooth devices to the udev rules. I copied this rule and added manually.
              I guess the question now is: How do I know how to manually create this file?
              I hope this helps anyone with a Matricom trying to use Recalbox.
