    Question concernant skraper
    Community projects
    concernant skraper
    6
    9
    1394
    • jfgelle
      jfgelle last edited by
      Je possède une collection de rom déjà scraper avec les images cependant j'aimerais rescrapper mes jeux pour avoir la description en français.
      Ma question est donc : peut on uniquement scraper la description des jeux sans toucher aux images ?? J'utilise skraper pour le moment et je n'ai trouver aucune option correspondant à sa 😕
      nexusone13 1 Reply Last reply Reply Quote 0
      • nexusone13
        nexusone13 @jfgelle last edited by
        Bonjour @jfgelle , Si tu ne trouves pas avec Skrapper, tu peux essayer ARRM, qui permet de faire cela. Voir le wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=scrape_text_only_fr
        ARRM (Another Gamelist, Roms manager, and Scraper for Recalbox, Batocera, Retropie) : http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
        Wiki ARRM: http://www.jujuvincebros.fr/wiki/arrm/
        Discord: https://discord.gg/p7QsBTS
        jfgelle 1 Reply Last reply Reply Quote 0
        • jfgelle
          jfgelle @nexusone13 last edited by
          @nexusone13 cool merci je vais tester sa ce soir !!
          • Fefo81
            Fefo81 last edited by
            Hi guys! I don’t speak French but I got some parts of the conversation and I think I have a similar problem. In the last two days Skraper saves only text info and it does not save videos or pictures for Recalbox. What’s the other scraper you suggested?
            Cheers
            Seiya nexusone13 Scavy 3 Replies Last reply Reply Quote 0
            • Seiya
              Seiya @Fefo81 last edited by
              This post is deleted!
              • nexusone13
                nexusone13 @Fefo81 last edited by nexusone13
                Hi @Fefo81 , It's not a problem related to Skrapper, but with Screenscraper infrastructure. It's seems OK now. Here is the message posted by Screenscraper Team on their discord yesterday :
                "MarbleMad : Our servers are currently having problems with the connection between the two servers. We had to migrate our infrastructure back to one server, and we also decided to block the API to everyone without a registered account, and put in the software.
                We are currently investigating on the issue, and appeared without any modification on our part. We have identified a potential issue on the private network, because our servers are on different datacenters.
                We are asking you to be patient while we are working on the situation.
                Thanks for your understanding, and more importantly, stay safe for you and everyone near you."
                Problem seems to be solved, cause pictures and video can now be recovered
                  Scavy Global moderator @Fefo81 last edited by
                  @Fefo81 said in Question concernant skraper:
                  @redblueflame
                  • Fefo81
                    Thank you guys!
                    • EdwardEastham
                      EdwardEastham Banned last edited by
