    Nintendo64 on Recalbox 6.1
    nintendo64 recalbox 6.1
    • JorgeDamien
      JorgeDamien last edited by
      Hi, help solve the problem. I downloaded the recalbox image from the official site and installed it on the computer. All the consoles I needed worked great, but the nintendo 64 games started with a black screen. The sound is audible, the sound of pressing buttons, too. Settings did not change. In recalbox.conf global.videomode = CEA 1 HDMI (tvservice command output is "code": 1, "width": 1280, "height": 1024
      (installed batocera for the test - nintendo64 works well, but recalbox is needed)
      JorgeDamien 1 Reply Last reply Reply Quote 0
      • JorgeDamien
        JorgeDamien @JorgeDamien last edited by
        @JorgeDamien said in Nintendo64 on Recalbox 6.1:
        Hi, help solve the problem. I downloaded the recalbox image from the official site and installed it on the computer. All the consoles I needed worked great, but the nintendo 64 games started with a black screen. The sound is audible, omegle discord xender the sound of pressing buttons, too. Settings did not change. In recalbox.conf global.videomode = CEA 1 HDMI (tvservice command output is "code": 1, "width": 1280, "height": 1024
        thankyou my issue has been solved
