    Solved Recalbox with Radeon HD 6320
    Emulator Arcade/PC/Console
    • SuperPuissant
      SuperPuissant last edited by
      Hello,
      taking advantage of this new thread to raise a problem that I have.
      I've installed the 6.1.1 on a HP hp t610 thin client - APU T56N AMD with a Radeon HD 6320 GPU, the first boot is perfect, then all the other time it won't boot and stays stuck with error message xinit: giving up xinit: unable to connect to x server.
      I've tried with both x64 and x86 version. Any hint?
        Hello
        recalbox is not compatible with Radeaon card yet.
        • SuperPuissant
          Hey,
          thanks for your quick answer, out of curiosity, do you know why the first boot works perfectly fine?
          thanks!
