    Settings on monitor Sony PVM 14M2U CRT!!!!
    settings monitor sony pvm 14m2u
    • AmirKing
      AmirKing last edited by
      Hello,
      I can't find the right setting with my Sony PVM 14M2U monitor.
      I have tried various configurations, but the screen is never aligned correctly.
      Currently used:
      Raspberry Pi 3b
      Recalbox 18.07.13
      Gert-VGA VGA666 Adapter Board
      VGA Male to BNC Male Adapter (5 BNC. 3 RGB + 2 sync H / V)
      This is the configuration in the "config.txt" file:
      disable_splash=1
      disable_overscan=1
      gpu_mem_256=128
      gpu_mem_512=256
      gpu_mem_1024=512
      avoid_safe_mode=1
      kernel=zImage
      overscan_scale=0
      disable_audio_dither=1
      dtparam=audio=on
      dtoverlay=vga666
      enable_dpi_lcd=1
      display_default_lcd=1
      dpi_group=2
      dpi_mode=87
      hdmi_timings=320 1 16 30 34 240 1 2 3 22 0 0 0 60 0 6400000 1
      hdmi_group=2
      hdmi_mode=87
      I believe that the problem is of the "hdmi_timings" line, in fact even with other values taken from the web, I always get unsatisfactory results. But isn't there any way to put the correct values based on my monitor?
      AmirKing 1 Reply Last reply Reply Quote 0
      • AmirKing
        AmirKing @AmirKing last edited by
        @amirking said in Settings on monitor Sony PVM 14M2U CRT!!!!:
        Hello,
        Currently used:
        Raspberry Pi 3b
        Recalbox 18.07.13
        disable_splash=1
        disable_overscan=1
        gpu_mem_256=128
        gpu_mem_512=256
        gpu_mem_1024=512
        avoid_safe_mode=1
        kernel=zImage
        overscan_scale=0
        dtparam=audio=on
        dtoverlay=vga666
        enable_dpi_lcd=1
        dpi_group=2
        dpi_mode=87
        hdmi_group=2
        hdmi_mode=87
        Hello,
        Currently used:
        Raspberry Pi 3b
        Recalbox 18.07.13
        disable_splash=1
        disable_overscan=1
        gpu_mem_256=128
        gpu_mem_512=256
        gpu_mem_1024=512
        avoid_safe_mode=1
        kernel=zImage
        overscan_scale=0
        dtparam=audio=on
        dtoverlay=vga666
        enable_dpi_lcd=1
        dpi_group=2
        dpi_mode=87
        hdmi_timings=320 1 16 30 34 240 1 2 3 22 0 0 0 60 0 6400000 1 https://check-distance.com/route/atlanta-ga/macon-ga
        hdmi_group=2
        hdmi_mode=87
        There is no "perfect" setting as they all need to be adjusted on a case by case basis depending on what the monitor needs. So in short, someone elses values could completely screw you up if they varied drastically from your original values.
