    Wifi Adaptor not working
    wifi adaptor
    • GeneralMilkshake
      GeneralMilkshake last edited by
      Ok, small problem. I have a wifi dongle that came from a raspi starter kit, and it works on any other OS I've tried. Recalbox, the one which has half of its best features on wifi (like Kodi and rom transferring), doesn't work with it. This is a shame, because Recalbox is probably the most usable gaming OS out there. To be specific, it is a Realtek RTL8188CU Wireless LAN 802.11n USB 2.0 Network Adapter. I tried the config thing, but that didn't work.
      • ivwshane
        ivwshane last edited by
        Does Internet work if you use a physical connection?   I've had a couple of recalbox's that wouldn't connect to a network no matter what, WiFi or hardwire. The only thing that fixed the issue was a full reinstall.
        • GeneralMilkshake
          yes. It works through ethernet.
          • conaire-paul-meenan
            conaire-paul-meenan last edited by
            That's the same problem I'm having they should just use the same WiFi config options from retropi
            • styletwo-wan
              styletwo-wan last edited by
              recalbox supports WPA only.
