    How to disable hciuart on Raspberry Pi 3 B+?
    GamePad/GPIO/USB encoder
    disable hciuart
    • Voytex86
      Voytex86 last edited by Voytex86
      Hello to all RecalBox enthusiasts.
      I want to use an external USB Bluetooth dongle for my controller so I'm trying to disable onboard WiFi and Bluetooth on my RPi 3 B+ (I won't be using WiFi, so I want to turn it off too).
      After logging into the terminal as a root (user: root, password: recalboxroot) I typed the following commands:
      1. "mount -o remount, rw /boot" to remount partition on read-write
      2. "nano /boot/config.txt" to edit the file located at /boot/config.txt
      Then I've added to the config.txt file this overlays:
      #Disable onboard WiFi and Bluetooth
      dtoverlay=pi3-disable-bt
      dtoverlay=pi3-disable-wifi
      Then closed and saved the file with "CTRL + X", "Y" and "ENTER".
      Now I have to disable hciuart but the command "sudo systemctl disable hciuart" doesn't work at all 😞
      After typing it in, the terminal shows me "-sh: sudo: command not found" 😞
      Is there any other way to disable hciuart?
      Thank you in advance for any tips.
      Regards.
        Hello
        no need sudo command, because in recalbox, user is root.
        the correct command line is :
        systemctl disable hciuard
        Voytex86 1 Reply Last reply Reply Quote 1
        • Voytex86
          Voytex86 @acris last edited by
          @acris Thank you for your quick reply, but after entering the command "systemctl disable hciuart" the terminal responds to me as follows: "-sh: systemctl: command not found".
          I don't know what I'm doing wrong, but this command does not work 😞
          • Voytex86
            After some testing, I've realised that there is no need for disabling hci_uart in relalbox 6.1.1 because my USB bluetooth dongle works well on default settings. There is no need for disabling RPi's 3B+ onboard bt module too (by adding dtoverlay=pi3-disable-bt in config. txt).
