    Nvidia troubleshooting installation
    nvidia troubleshooting installation
    • fabfish
      fabfish last edited by
      Hello, I have an ASUS N55SF laptop with NvidiaGT555M graphics card. Despite the installation of the latest stable version 6.1.1 I get a message like "Xlib: extension" GLX "missing on display": 0.0 ".
      Is there a trick to successfully loading the right library? or can this card not be taken into account?
      Thanks for your help
      strodown 1 Reply Last reply Reply Quote 0
      • strodown
        strodown @fabfish last edited by
        @fabfish hello for the moment there is a problem with the installation script of the nvidia driver, which I think should not apply to your configuration.
        can you tell me if in version 6.1 you have the same problem or if everything works correctly ?
        Recalbox X86_64 :
        X-Arcade
        Lightgun Mayflash Dolphin-bar
        fabfish 1 Reply Last reply Reply Quote 0
        • fabfish
          fabfish @strodown last edited by
          @strodown Hi , thank you for your answer. Can you give me a link to download a 6.1 version : I only found a link for the 6.1.1 version ...
