    What's the trick to get a 360 controller to work?
    whats trick 360
    • JesusCamden
      JesusCamden last edited by
      I have recalbox 6.1.1, and I have been trying to get my Xbox 360 controllers connected. I read they should work out of box since 4,so what I am I doing wrong?
      I went into pair Bluetooth, turned on controller hold sync button, select from a random Mac address. Sometimes it says connected, but I can't control anything, sometimes it says can't connect and goes back the Mac address list. I try another, still nothing.
      I have also tried starting the sync on the controller before starting recalbox Bluetooth config, not pressing sync, etc. I have also tried 3 different controllers.
      Do xbox controllers work?
      Sandalen_Jesus JesusCamden 2 Replies Last reply Reply Quote 0
      • Sandalen_Jesus
        Sandalen_Jesus @JesusCamden last edited by
        @jesuscamden as far as i know, xbox 360 controllers have no Bluetooth. The newer Xbox one controllers have Bluetooth.
        • ian57
          ian57 Staff last edited by
          @JesusCamden for xbox 360 controllers you need the M$ specific adapter since M$ does not use standard BT for these controllers. https://www.amazon.fr/Récepteur-Adaptateur-récepteur-Microsoft-Pratique/dp/B07MBLTKXG/ref=pd_sbs_107_1/262-1644559-0459613?_encoding=UTF8&pd_rd_i=B07MBLTKXG&pd_rd_r=cba5aa76-9dc4-43ca-92e7-0e1cc8a6adf8&pd_rd_w=H6pXD&pd_rd_wg=TCVz8&pf_rd_p=72159c7a-2bb2-4a15-aa35-b315ce8f5c64&pf_rd_r=A4ZD8EJMX4ECH7RJR3AD&psc=1&refRID=A4ZD8EJMX4ECH7RJR3AD
          • JesusCamden
            JesusCamden @JesusCamden last edited by
            @jesuscamden said in What's the trick to get a 360 controller to work?:
            I have also tried starting the sync on the controller before startin https://shareit.onl/ https://appvn.onl/ g recalbox Bluetooth config, not pressing sync, etc. I have also tried 3 different controllers.
            Once you have MotionJoy, just select your controller from the drop-down list at the top, pick the controller you want to emulate (The XBox 360 Controller Emulator works very well, IMO), and click enable.
            101.4k
