    Configuring Joystick on KODI reset when Exit
    MediaCenter & Dualboot
    configuring joystick kodi reset
    • darth
      darth last edited by
      Hello team, how are you?,
      I am trying to configure custom buttons on my joystick for Kodi. I do it from the Kodi configuration menu, I assign the buttons correctly and everything works fine until I exit the app.
      When I go back to ES, Kodi resets the buttons to the original buttons and my changes are not saved.
      Any Idea on how to solve this?
      Thank you.
      • neo207
        neo207 last edited by
        This topic is quite old but i have the same issue. is there a solution yet?
        • neo207
          can nobody help? any chance i can save the config file for the inputs in kodi? i have to calibrate my jostick each time i open KODI, i don't think that this is normal...
