    help with my arcade
    help arcade
    • AlexCamden
      AlexCamden last edited by
      Good morning people, I apologize for my English, I need your help to clarify some doubts, I currently have a PC with the following specifications: intel pentium 3ghz 3Gb Ram
      I have batocera 5.24 installed. I have problems emulating naomi / atomisware games, the games do not play, just load a few seconds and return to the previous screen. I tried to put my games in both the Naomi folder and the atomisware folder and it gives the same result. Will you have any idea that it may be failing? on the other hand, is it true that there are naomi / atomisware games converted to MAME format?
      first of all, Thanks
        Hello @AlexCamden
        it's not batocera forum but recalbox forum.
        You need to go batocera forum for help
        100.8k
