    random shutdowns and safe shutdown not working (Megapi Case)
    random shutdowns safe megapi case
    • Madmeggo
      Madmeggo last edited by Madmeggo
      Hello everyone!
      I recently set up my Recalbox (Raspberry Pi 3B) wich I didn't use for about 3 years, and installed the newest version 6.1.1
      Also I bought the Megapi-Case from Retroflag.
      At first everything ran well, although I never got the safe shutdown and the reset to work (using the PIN356ONOFFRESET option). Every time I press the reset button, the system just hard resets, instead of resetting the current game.
      The safe shutdown option is turned on inside the case.
      Also after some time my Recalbox started to randomly shutdown itself (a proper shutdown with the warning "don't turn off system") I can't see any pattern. Sometimes it happens after 2 or 3 Minutes, sometimes it takes longer. It doesn't matter if I am ingame or in the menu.
      I installed everything correctly and I don't know what to do. I just want to finally play my retro games again, without having to worry how long it will be ubtil I get interrupted 😞
      It would be great if anybody could help me!
      Edit: I would upload my recalbox.conf but I don't know how
      • Madmeggo
        This is what my recalbox.conf looks like:
        system.power.switch=PIN356ONOFFRESET    # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
        ## fbcp FrameBuffer Copy Program
        ## For small TFT screen on GPIO and SPI
        ## See https://github.com/recalbox/recalbox-os/wiki/Utility---Use-of-fbcp-for-small-TFT-screen-%28EN%29 for details
        ## Needed for Waveshare 3.2" 3.5" TFT screen, 2.8" Adafruit screen
        ## See https://github.com/recalbox/recalbox-os/wiki/TFT-Screen-SPI-Bus-%28EN%29
        ## for support and configuration details needed by /boot/config.txt
        system.fbcp.enabled=0
        ## Splash screen duration
        ## 0: Video will be played for 20 seconds (default)
        ## -1: All the video will be played (it won't be stopped automatically)
        ## >0 : Time before the video will be stopped (in seconds)
        system.splash.length=0
        system.manager.enabled=1
        ## Currently, only version 2 is available
        system.manager.version=2
        ## Recalbox security
        # enforce security
        # samba password required
        # disable virtual gamepads
        system.security.enabled=0
        ## Recalbox API (REST)
        system.api.enabled=0
        ## Allow a specific resolution for ES only from the command : tvservice -m [MODE]
        ## Leave commented for the default usual behaviour
        ;system.es.videomode=CEA 4 HDMI
        ## EmulationStation
        ### menu style
        ### default -> default all options menu
        ### none -> no menu except the game search menu
        ### bartop -> less menu, only needed for bartops
        emulationstation.menu=default
        ### Select a system to show on boot (use rom directory name) (string)
        emulationstation.selectedsystem=megadrive
        ### Show the gamelist of the first or selected system on boot (0,1)
        emulationstation.bootongamelist=0
        ### Disable system view. ES will boot and show ONLY the first or selected system (0,1)
        emulationstation.hidesystemview=0
        ### Pa**e Gamelists only. Show only games listed in gamelist.xml files (0,1)
        emulationstation.gamelistonly=0
        ### Force basicgameList view to be displayed, even if your game systems are scraped (0,1)
        emulationstation.forcebasicgamelistview=0
        ## Videosnaps
        ### Delay before videosnaps start, in millisecond. Default: 2s
        ;emulationstation.videosnaps.delay=2000
        ### Video loop times. 0 = no video. 1 or more = the video loops x times before fading out
        ;emulationstation.videosnaps.loop=1
        ## Scrapers
        ### ScreenScraper.fr
        ### Force media region - if not defined, region is taken from system.language. Default: us
        ;scraper.screenscraper.region=eu
        ### Force text language - if not defined, region is taken from system.language. Default: en
        ;scraper.screenscraper.language=fr
        ### Choose the media to download among:
        ### screenshot: game screenshot
        ### title     : game title screenshot
        ### box2d     : Front case
        ### box3d     : 3D rendered case
        ### mixv1     : Recalbox special mix image V1 (default)
        ### mixv2     : Recalbox special mix image V2
        ;scraper.screenscraper.media=mixv1
        ### ScreenScraper account
        ;scraper.screenscraper.user=
        ;scraper.screenscraper.password=
        ## Emulator special keys
        kodi.enabled=1
        ## Start kodi at launch (0,1)
        kodi.atstartup=0
        kodi.xbutton=1
        ## Allow a specific resolution for Kodi only from the command : tvservice -m [MODE]
        ## By default is using the default resolution of your screen
        kodi.videomode=default
        ;kodi.network.waittime=10
        ## Hyperion
        ## Hyperion allows you to use an ambilight like led system on your recalbox
        ## Use hypercon to create your configuration file, and copy it in /recalbox/share/system/configs/hyperion/hyperion.config.json
        hyperion.enabled=0
        ## Set system hostname
        system.hostname=RECALBOX
        ## Activate wifi (0,1)
        wifi.enabled=1
        ## Set wifi region
        ## More info here: https://github.com/recalbox/recalbox-os/wiki/Wifi-country-code-(EN)
        wifi.region=US
        ## Wifi SSID (string)
        wifi.ssid=xxxxxxxxxx
        ## Wifi KEY (string)
        ## after rebooting the recalbox, the "new key" is replace by a hidden value "enc:xxxxx"
        ## you can edit the "enc:xxxxx" value to replace by a clear value, it will be updated again at the following reboot
        wifi.key=xxxxxxxxxxx
        ## Wifi - static IP
        ## if you want a static IP address, you must set all 3 values (ip, gateway, and netmask)
        ## if any value is missing or all lines are commented out, it will fall back to the
        ## default of DHCP
        ;wifi.ip=manual ip address
        ;wifi.gateway=new gateway
        ;wifi.netmask=new netmask
        # secondary wifi (not configurable via the user interface)
        ;wifi2.ssid=new ssid
        ;wifi2.key=new key
        # third wifi (not configurable via the user interface)
        ;wifi3.ssid=new ssid
        ;wifi3.key=new key
        ## Samba share
        system.samba.enabled=1
        ### Virtual Gamepads
        ### SSH
        system.ssh.enabled=1
        audio.device=hdmi
        ## Set system volume (0..100)
        audio.volume=81
        audio.bgmusic=1
        # Enable ERTM
        controllers.bluetooth.ertm=0
        controllers.ps3.enabled=1
        ## Choose a driver between bluez, official and shanwan
        ## bluez -> bluez 5 + kernel drivers, support official and shanwan sisaxis
        ## official -> sixad drivers, support official and gasia sisaxis
        ## shanwan -> shanwan drivers, support official and shanwan sisaxis
        controllers.ps3.driver=bluez
        # ------------ D2 - GPIO Controllers ------------ #
        ## GPIO Controllers
        controllers.gpio.enabled=0
        controllers.gpio.args=map=1,2
        ## Custom mk_gpio arguments,
        ## map=5 gpio1=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk  for one controller,
        ## map=5 gpio1=pin1,pin2,pin3,.....,pin12,pin13
        ## map=5,6 gpio1=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk gpio2=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk for 2 (map=5,map=5,6)
        ## map=5,6 gpio1=gpiox,gpioy,gpioz,.....,gpiou,gpiov gpio2=gpiox,gpioy,gpioz,.....,gpiou,gpiov
        # where gpiox,gpioy,gpioz ... are NOT pin numbers on the connector, BUT location gpio numbered as in
        # https://www.raspberrypi-spy.co.uk/wp-content/uploads/2012/06/Raspberry-Pi-GPIO-Layout-Model-B-Plus-rotated-2700x900.png
        ## Set pin to -1 to disable it
        # controllers.gpio.args=map=5,6 gpio=4,17,27,22,10,9,25,24,23,18,15,14,2 gpio2=11,5,6,13,19,26,21,20,16,12,7,8,3
        ## MCP configuration : GPIO and MCP can be used together. You can mix them.
        ## map=0x20,0x21 for 2 mcp23017 on i2c bus
        #controllers.gpio.args=map=0x20,0x21,5,6 gpio=4,17,27,22,10,9,25,24,23,18,15,14,-1 gpio2=11,5,6,13,19,26,21,20,16,12,7,8,-1
        # ------------ D3 - Steam Controllers ------------ #
        ## Enable steam controller service
        controllers.steam.enabled=0
        ## DB9 Controllers
        controllers.db9.enabled=0
        ## db9 arguments
        controllers.db9.args=map=1
        ## Gamecon controllers
        ## Enable gamecon controllers, for nes, snes, psx (0,1)
        controllers.gamecon.enabled=0
        ## gamecon_args
        controllers.xarcade.enabled=1
        system.language=en_US
        system.kblayout=de
        ## Set you local time
        ;system.timezone=Europe/Paris
        updates.enabled=1
        # Update type : default to stable
        updates.type=stable
        ## use 'auto' : switches to CEA 4 HDMI if supported, else keep the current resolution
        ## (string)
        global.videomode=CEA 4 HDMI
        ## Shader set
        ## (none, retro, scanlines)
        global.shaderset=retro
        global.integerscale=1
        global.shaders=
        global.ratio=auto
        global.smooth=0
        global.rewind=1
        global.autosave=0
        global.retroachievements=1
        global.retroachievements.hardcore=0
        global.retroachievements.username=xxxxxxxx
        global.retroachievements.password=xxxxxxxx
        global.inputdriver=auto
        ## Demo screensaver parameters
        ## Set the system list from which ES will run random games.
        ## Empty list or unexisting key means all available systems
        global.demo.systemlist=mame
        ## Default demo game sessions last 90s. Change this value if you want shorter or longer sessions
        ;global.demo.duration=90
        ## Default game info screen duration lasts 6s. Change this value if you want shorter or longer info screens.
        ;global.demo.infoscreenduration=6
        ## Retroarch AI Translation service
        ## Comment out or set to 0 the following key if you don't want the AI service
        global.translate=1
        ## Set the source and the target languages.
        ## Allowed language list: EN, ES, FR, IT, DE, JP, NL, CS, DA, SV, HR, KO, ZH_CN, ZH_TW, CA, BG, BN, EU, AZ, AR, SQ,
        ##                        AF, EO, ET, TL, FI, GL, KA, EL, GU, HT, IW, HI, HU, IS, ID, GA, KN, LA, LV, LT, MK, MS,
        ##                        MT, NO, FA, PL, PT, RO, RU, SR, SK, SL, SW, TA, TE, TH, TR, UK, UR, VI, CY, YI
        ## Setting the translate.from key to a specified language may speed up or give more accurate results
        ## If translate.to key is commented, the default value is extracted from system.language or, if system.language is
        ## undefined, set to auto (=EN).
        global.translate.from=auto
        global.translate.to=auto
        ## zTranslate API Key
        ## go to https://ztranslate.net and create an account.
        ## validate your account, then log in and go to the settngs page
        ## Look for the API Key at the bottom of the page, then uncomment the following key and paste your API Key:
        ;global.translate.apikey=YOUR_API_KEY_HERE
        ## Other translation service
        ## If you want to use another translation service or a custom API call, use this key to
        ## specify the url to call. If the key is not empty, it is used instead of zTranslation's API Key
        ;global.translate.url=
        ## Arcade metasystem
        ## Activate the Arcade metasystem to group all games from piFBA, FBN (libretro), MAME and optionally Neogeo
        ## into a single "Arcade" system.
        ;global.arcade=1
        ## You may want to specify its position in the system list. (Default: 0)
        ## Negatives values may be used to tart from the end (-1 = last position)
        ;global.arcade.position=0
        ## Include NeoGeo or not (default: 1)
        ;global.arcade.includeneogeo=1
        ## Hide included system or leave them in the system list (default: 1)
        ;global.arcade.hideoriginals=1
        ## You can override the global configurations here
        ## Here is the snes example
        ;snes.videomode=CEA 4 HDMI
        snes.core=snes9x2010
        ;snes.ratio=16/9
        ;snes.smooth=0
        ;snes.rewind=1
        ;snes.autosave=0
        ;snes.emulator=libretro
        ;snes.integerscale=0
        ## If you do not want recalboxOS to generate the configuration for the emulator:
        ## Default cores for RPi3
        ## NeoGeo emulator
        neogeo.emulator=libretro
        ## If you set libretro as neogeo.emulator, the line below sets the retroarch core (fbneo, mame2000)
        neogeo.core=fbneo
        n64.videomode=DMT 4 HDMI
        # n64.videomode=default
        ## Dreamcast emulator
        ## Like N64, such a CPU intensive emulator needs a small resolution
        ## Consider DMT 4 HDMI (640*480) or DMT 9 HDMI (800*600). If you have a black screen on dreamcast, try DMT 9 HDMI here
        dreamcast.videomode=DMT 4 HDMI
        ## Include or exclude a particular system from the demo screensaver
        ## You may change the global.demo.systemlist key or include/exclude every single system
        ;snes.demo.include=0
        ## Set the session duration for a particular system
        ;snes.demo.duration=90
        # ------------ J - NETPLAY PARAMETERS ----------- #
        ## All these values are handled by Recalbox itself
        global.netplay=1
        global.netplay.nickname=
        global.netplay.port=55435
        global.netplay.relay=
        global.netplay.systems=fba_libretro,mame,mastersystem,megadrive,neogeo,nes,pcengine,sega32x,sg1000,snes,supergrafx
        global.netplay.lobby=http://lobby.libretro.com/list/
        global.quitpresstwice=0
        fba_libretro.flatfolder=0
        fba_libretro.sort=0
        gbc.flatfolder=0
        gbc.sort=0
        megadrive.flatfolder=0
        megadrive.sort=0
        nes.flatfolder=0
        nes.sort=0
        mame.flatfolder=0
        mame.sort=0
        imageviewer.flatfolder=0
        imageviewer.sort=0
        amiga600.flatfolder=0
        amiga600.sort=0
        amstradcpc.flatfolder=0
        amstradcpc.sort=0
        gb.flatfolder=0
        gb.sort=0
        pcengine.flatfolder=0
        pcengine.sort=0
        psx.flatfolder=0
        psx.sort=0
        segacd.flatfolder=0
        segacd.sort=0
        If you need any other information, please let me know
