    GBA emulator slow on RaspberryZero W
    slow raspberryzero
    • Nicola Silveri
      Nicola Silveri last edited by acris
      Hi I have this modded GBA SP with Raspberry Zero and SPI screen Waveshare 3.2 320x240 LCD (C)
      when i use GBA roms the games are very slow
      i put here my config.txt if someone can help me
      CONFIG.TXT
      # uncomment if you get no picture on HDMI for a default "safe" mode
      #hdmi_safe=1
      disable_overscan=1
      # uncomment to force a specific HDMI mode (this will force VGA)
      #hdmi_group=1
      #hdmi_mode=1
      # Sound output. Set to 0 or comment for autodetect, 1 for DVI, 2 to force HDMI.
      #hdmi_drive=2
      # Using /etc/modules is deprecated and no longer supported on 4.4 kernel
      # So manually enable audio
      dtparam=audio=on
      config_hdmi_boost=0
      # force hdmi while the tv can take time before sending the signal on the hdmi output
      hdmi_force_hotplug=1
      # uncomment for composite PAL
      #sdtv_mode=2
      # uncomment for lirc-rpi
      #dtoverlay=lirc-rpi
      # if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or give a low resolution because tv had no enough time to initialize it
      boot_delay=3
      # uncomment if you don't want the rainbow at startup
      disable_splash=1
      # default CEC name
      cec_osd_name=recalbox
      # Overclock
      gpu_mem_256=128
      gpu_mem_512=256
      gpu_mem_1024=448
      avoid_safe_mode=1
      kernel=zImage
      # Raise the first security limit up to 70° instead of 60°
      temp_soft_limit=70
      #dtoverlay=gpio-key,gpio=21,keycode=108,label="KEY_DOWN"
      #dtoverlay=gpio-key,gpio=12,keycode=103,label="KEY_UP"
      #dtoverlay=gpio-key,gpio=6,keycode=105,label="KEY_LEFT"
      #dtoverlay=gpio-key,gpio=14,keycode=106,label="KEY_RIGHT"
      #dtoverlay=gpio-key,gpio=16,keycode=28,label="KEY_ENTER"
      #dtoverlay=gpio-key,gpio=15,keycode=14,label="KEY_BACKSPACE"
      #dtoverlay=gpio-key,gpio=26,keycode=30,label="KEY_A"
      #dtoverlay=gpio-key,gpio=19,keycode=48,label="KEY_B"
      #dtoverlay=gpio-key,gpio=5,keycode=19,label="KEY_R"
      #dtoverlay=gpio-key,gpio=2,keycode=113,label="KEY_MUTE"
      dtoverlay=pwm-audio-pi-zero
      dtoverlay=waveshare32c:rotate=270,speed=50000000,fps=60 #rotate=lite
      framebuffer_width=320
      framebuffer_height=240
      hdmi_cvt=320 240 60 1 0 0 0
      hdmi_group=2
      hdmi_mode=87
      #hdmi_timings=320 0 28 18 28 480 0 2 2 4 0 0 0 60 0 32000000 6
      #hdmi_timings=240 1 38 10 20 320 1 20 4 4 0 0 0 60 0 6400000 1
      #dtparam=spi=on
      #force_eeprom_read=0
      #overclock
      arm_freq=1000
      gpu_freq=500
      core_freq=500
      sdram_freq=500
      sdram_schmoo=0x02000020
      over_voltage=2
      sdram_over_voltage=2
        Hello
        try another core in advance game option
        • Nicola Silveri
          @acris i tried but i have always the same problem
