    Installing on Intel TV Stick
    installing intel stick
    • bydgoszczanin
      bydgoszczanin last edited by
      Hello. I want install Recalbox on internal memory of Kiano SlimStick. It's any chance to do it ?
      Sorry for my bad english, but I'm from Poland.
        Zing Global moderator Translator @bydgoszczanin last edited by
        @bydgoszczanin No, the system is not compatible with this device, and there is nothing that can be done.
        • ordovice
          ordovice last edited by
          @bydgoszczanin said in Installing on Intel TV Stick:
          Kiano SlimStick
          Since it's a 64 bit Atom processor you could try using Hiren's Boot PE, load balena Etcher portable and the uncompressed x64 image on your hirens USB, and then write to the storage. It should work, but in all reality you probably won't get the greatest performance.
