    Unsolved PS1 DualShock controlle
    GamePad/GPIO/USB encoder
    2692
    • MagNeato
      MagNeato last edited by
      I have the same problem, and a few more details, when trying to get a PS1 DualShock controller working with a USB adapter.
      All (buttons and thumbsticks) work correctly in:
      -recalbox v4.0.0-beta5
      X, O and Square buttons do not register:
      -recalbox 6.1.1 Dragonblaze
      -Retropie xxxx
      ..meaning, the "Configuring" dialogue in the recalbox menu can't be completed because the SNES equivalents, A, B and Y don't register button presses.
      The sdl2-jstest output shows only 14 (0-13) button codes, but there should be 3 more:
      recalbox 6.1.1 output:
      sdl2-jstest -l
      Found 1 joystick(s)
      Joystick Name: 'Sony PLAYSTATION(R)3 Controller'
      Joystick Path: '/dev/input/event1'
      Joystick GUID: 030000004c0500006802000011810000
      Joystick Number: 0
      Number of Axes: 6
      Number of Buttons: 13
      Number of Hats: 0
      Number of B***s: 0
      GameController:
      Name: 'PS3 Controller'
      Mapping: '030000004c0500006802000011810000,PS3 Controller,a:b0,b:b1,back:b8,dpdown:b14,dpleft:b15,dpright:b16,dpup:b13,guide:b10,leftshoulder:b4,leftstick:b11,lefttrigger:a2,leftx:a0,lefty:a1,rightshoulder:b5,rightstick:b12,righttrigger:a5,rightx:a3,righty:a4,start:b9,x:b3,y:b2,'
      Axis code 0: 0
      Axis code 1: 1
      Axis code 2: 2
      Axis code 3: 3
      Axis code 4: 4
      Axis code 5: 5
      Button code 0: 307
      Button code 1: 310
      Button code 2: 311
      Button code 3: 312
      Button code 4: 313
      Button code 5: 314
      Button code 6: 315
      Button code 7: 317
      Button code 8: 318
      Button code 9: 544
      Button code 10: 545
      Button code 11: 546
      Button code 12: 547
      And when I run "sdl2-jstest -t 0", the three mentioned buttons do show any input when pressed but if I press another button like the right trigger, I see this message:
      "INFO: The key you just pressed is not recognized by SDL. To help get this fixed, please report this to the SDL forums/mailing list https://discourse.libsdl.org/ EVDEV KeyCode 313"
      Compare to recalbox v4 output:
      sdl2-jstest -l
      Found 1 joystick(s)
      Joystick Path: '/dev/input/event0'
      Joystick GUID: 030000004c0500006802000011010000
      Joystick Number: 0
      Number of Axes: 4
      Number of Buttons: 19
      Number of Hats: 0
      Number of B***s: 0
      GameController:
      Mapping: '030000004c0500006802000011010000,PS3 Controller,a:b14,b:b13,back:b0,dpdown:b6,dpleft:b7,dpright:b5,dpup:b4,guide:b16,leftshoulder:b10,leftstick:b1,lefttrigger:b8,leftx:a0,lefty:a1,rightshoulder:b11,rightstick:b2,righttrigger:b9,rightx:a2,righty:a3,start:b3,x:b15,y:b12,'
      Axis code 0: 0
      Axis code 1: 1
      Axis code 2: 2
      Axis code 3: 5
      Button code 0: 288
      Button code 1: 289
      Button code 2: 290
      Button code 3: 291
      Button code 4: 292
      Button code 5: 293
      Button code 6: 294
      Button code 7: 295
      Button code 8: 296
      Button code 9: 297
      Button code 10: 298
      Button code 11: 299
      Button code 12: 300
      Button code 13: 301
      Button code 14: 302
      Button code 15: 303
      Button code 16: 704
      Button code 17: 705
      Button code 18: 706
      Both the number of axis and buttons differ, but all the PS1 buttons map to something. I don't understand why any PS[1,2,3] (even non dual shock) gamepad would ever have less than 14 total buttons.
      The recalbox version I've been using came from a pre-built image:
      head /recalbox/recalbox.msg
      v4.0.0-beta5
      • Updated libretro mame 2003 core. Fixes the ratio issue in mame.
      • Improved pads and gpio support for moonlight
      • Change location of PM2_HOME to fix a bug with API daemon
      • Disable printer sharing to reduce log output
      • Prevent MacOS from adding its .DS_store
      Is there something I can identify in this v4 build that I can roll into v6 will regain the working behavior?
      Is there a known procedure I'm missing to utilize a PS1 DS controller in recalbox 6?
      This is the adapter I'm using:
      Mcbazel PlayStation 2 Controller to USB Adapter for PC or Playstation 3 Converter Cable for Sony DualShock PS2 PS3 Controllers (NOT compatible with Dancing Mat Guitar Hero) - https://smile.amazon.com/gp/product/B000NJBD90/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
      • MagNeato
        I verified stock 4.0.0-beta5 (recalboxOS-4.0.0-beta5.zip) works with my adapter without any modification.
        The sdl2-jstest command oddly does not exist in this build though, which I don't understand.
        • MagNeato
          The build I've been using which works, is actually [17.12.02] - 2017-12-02 so I'm guessing at least v4.0.0-beta5 - 2017-12-02 work with my adapter.
          It looks like "head /recalbox/recalbox.changelog" is the correct command to see the version while /recalbox/recalbox.msg is old/invalid.
            Hello @MagNeato
            you are using an old version of recalbox which is no longer supported. we don't support anymore
            Please update your version, it may solve all the problems.
            Check this tutorial : https://github.com/recalbox/recalbox-os/wiki/PS3-controllers-drivers-(EN)
            Edit recalbox.conf with winscp + notepad++ or via share network.
            Try bluetooth, official or shanwan driver :
            controllers.ps3.driver=shanwan
            controllers.bluetooth.ertm=1
            • MagNeato
              Thank you for the reply.
              The PS1 controller works in the old version (4.x) . Some PS1 controller buttons do not work in the latest version (6.1.1). To few buttons are detected, as seen in the sdl2-jstest output.
              I tried your suggestion in 6.1.1, and see that both 6.1.1 and 4.0.0-beta5 are both using:
              /recalbox/share/system/recalbox.conf :
              controllers.ps3.driver=bluez
              I tried "official" and "shanwan" in 6.1.1, but it did not help.
                you need to forget and reboot recalbox
                every time you change the driver
                and reconfigure gamepad.
                @acris said in PS1 DualShock controlle:
                forget gamepad,
                reboot recalbox
                configure gamepad again.
                if doesn't work , please post archive support recalbox 6.1.1 only
                • MagNeato
                  This is a USB adapter (not bluetooth). Does the setting apply to USB?
                  Here is the support file from 6.1.1:
                  https://www66.zippyshare.com/v/HkKSvvki/file.html
                  I can't complete the 'configure gamepad' process because the X, O and Square buttons do not register button-presses.
                    @magneato said in PS1 DualShock controlle:
                    which adapter exactly ? link ?
                    • MagNeato
                      There's an Amazon link for it in my first post.
