    Unsolved GPi Case and PiSNES Configs
    GamePad/GPIO/USB encoder
    gpi case pisnes configs
    • Snip3rM00n
      Snip3rM00n last edited by
      I recently got a GPi case and set it up with a Raspberry Pi Zero W and installed Recalbox onto it. After testing around with some SNES games, I've noticed that the A/B and X/Y buttons are swapped (A button is mapped to B on the case, B to A, X to Y and Y to X). Doing some digging, I learned that I should be able to create a custom config file for the SNES and so I created the config file /recalbox/share/custom_configs/snes9x.cfg and added the line snes.configfile=/recalbox/share/custom_configs/snes9x.cfg to my recalbox.conf and for good measure I rebooted Recalbox. When I run SNES roms though, the custom config file is seemingly ignored. Is there something I am missing?
      Setup:
      Device: Retroflag GPi Case
      Board: Raspberry Pi Zero W (2017)
      SD Card: 32GB SanDisk Ultra (flashed with Recalbox using Etcher)
      Recalbox Version: 6.1.1 Dragonblaze
      RecalBox.conf file and custom snes9x.cfg file
      sixer_sixer 3 Replies Last reply Reply Quote 1
      • sixer_sixer
        sixer_sixer @Snip3rM00n last edited by
        @snip3rm00n Yo i've also tried and also did not work here
        • sixer_sixer
          @snip3rm00n OK I did the trick by editing the Python generator file in the terminal
          ssh root@192.168.0.xxx
          mount -o remount, rw /
          cd /usr/lib/python2.7/site-packages/configgen/generators/pisnes
          vi pisnesGenerator.py
          And re-mapping the keys
          RECALBOX_TO_PBCS_BUTTON_MAPPING = \
                  "up": "UP",
                  "down": "DOWN",
                  "left": "LEFT",
                  "right": "RIGHT",
                  "a": "B",
                  "b": "A",
          But it got side effects to save/load states indeed
          NB: expecting you have remap your emulationstation keys to a snes controller of course 🙂
          Following this post
          https://forum.recalbox.com/topic/19565/pisnes-fullscreen-since-last-update-6-1-1-dragonblaze
          • sixer_sixer
            This post is deleted!
            • Matze1980
              Matze1980 last edited by
              Go to the main menu (Start)
              Go to controller settings
              Go to Configure Controller
              Brings the Gpi case into Axis mode. Hold SELECT* + D-PAD LEFT for 5s. The device led will flash purple when done.
              *SELECT may have been replace by START on new firmware.
              Set up your controller.
              High
              Down
              Left
              Right
              Joystick can be skipped (press D-Pad down 4x)
              A
              B
              X
              Y
              Start
              Select
              L1
              R1
              Skip L2, R2, L3, R3 again (press D-Pad down 4x)
              Hotkey (press Select)
              Press B to finish OK
              Right B and A button in the SNES
              The D-Pad works with Scummvm
