    [Solved]I've copied a psx iso and none of my games are working now!
    mame
    1991
    • davmanypsp
      davmanypsp last edited by
      Hi, I have a lot or roms of different systems and all worked fine until now that none of them works (black screen and back to emulationstation), the only thing I have done before it happened is to copy a new game. Could be a filesystem corruption issue? In ES all my games are showing, it gave me no errors during copying and I ejected the card properly from the pc, as always. How could I fix it?
      • digitaLumberjack
        Hi, did you touch recalbox.conf ? What is your recalbox version ? Rpi version ? What is in the /root/recalbox.log file ?
        • davmanypsp
          Hi, no, I didn't touch that config file. It was working fine, just added one rom, and then none of my roms work. My version is 3.30 beta 16, RPI 2. I'm going to have a look at the log file.
          • digitaLumberjack
            Also, could you check the space left on the partition ? Menu -> System settings
            • davmanypsp
              For now I've discovered that the recalbox.conf file was damaged. I've repaired the filesystem on the pc and now I can open that file, but is empty. I'm making a backup of all my roms and I will try to update from the EmulationStation, and see what happens.
              • davmanypsp
                Updating didn't solve the issue, so I've formatted and fresh installed the beta 17. All seems to work well now. Thank you 🙂
