    VGA Display issue
    MediaCenter & Dualboot
    vga display issue
    • zoronoa02
      zoronoa02 last edited by
      Hello, my problem is that I want to convert a laptop into a recreational machine and I need the image to be reproduced on an external 4: 3 screen by VGA, recalbox recognizes it, but does not connect or remove the video signal directly by removing the cable, If I do that, only the initial charging and terminal screen is reproduced on the external monitor. Does anyone know how to fix it?
      • Unlocked by  Pitch64 Pitch64
      • Locked by  Pitch64 Pitch64
      • Restored by  Pitch64 Pitch64
