    [Problem] Controllers Not Working
    [problem]
    7868
    • mlookabaugh
      mlookabaugh last edited by
      I've just set up a Recalbox, and I can't get any controllers to function. I'm quite sure it's something stupid I'm doing. The recalbox was set up per instructions on the main page.  I was also able to configure wireless and copy all roms over that way.  They register in the UI, and seem to launch fine (via keyboard).   Everything on the software side seems great. But I can't get controllers to work. I have a brand-new PS3 Dualshock controller, which is fully charged.  I plug it in to the RP, and all four lights flash on and off.  After 10 seconds, I disconnect it, and press the PS button.  The four lights flash again, and then go dark, but nothing else happens.  The controller does not work in the games.  I see from watching videos that I should get a single light come on as makes a connection with the system. Thought perhaps it was a controller issue, so I got a Microsoft USB XBox-360 controller.  This one is wireless and has a dongle that plugs into the PI.  When it's connected, I can see the controller in the configuration screen, and can select it for spots 1-4.  But still nothing happens.  I can't move the UI at all, and it doesn't work in games. Here's my setup: Rasberry Pi 2 , Model B, 1 GB Ram (CanaKit + WiFi dongle) 32 GB MicroSD (formatted per instructions with SDFormatter) recalboxOS-v3.3.0-beta17 Any help would be greatly appreciated. Thanks very much for your time! Mark
        Hello, so let's try to resolve your problems.
        Can you try other ps3 drivers ? In recalbox, 3 drivers are available original, shanwan, gasia. So you can switch them through your recalbox.conf file. You switch, reboot, reappair (plug, wait 10sec, unplug and pray) with all drivers and you give us a feedback.
        Thought perhaps it was a controller issue, so I got a Microsoft USB XBox-360 controller. This one is wireless and has a dongle that plugs into the PI. When it’s connected, I can see the controller in the configuration screen, and can select it for spots 1-4. But still nothing happens. I can’t move the UI at all, and it doesn’t work in games.
        So you have a wireless xbox360 gamepad + a xbox wireless dongle like this one and your gamepad is not functional ? You can try to activate xboxdrv driver through you recalbox.conf That add a better support with xbox360 gamepads.
        • mlookabaugh
          I tried all three PS3 drivers with no success.  (1) edited config to select the ps3 driver (and verify all other drivers off), (2) restart recalbox, (3) plugin in controller for 10 seconds, (4) disconnect.  In all cases, the PS3 dualshock blinked all four lights when connected.  When disconnected, it flashed all four lights again when trying to connect.  No connection was made. For the XBOX controller,  (1) turned off PS3 driver, and enabled XBOX driver, (2) connected wireless usb dongle for controller, (3) restarted recalbox.   It was not able to control the screen.  When I select "Configure a controller", it shows 2 gamepads detected, but pressing all buttons on the device did not register any activity.  Selected controller input #0, and went from "default" to XBOX controller (forget exact text) which appeared in the list.  Again, no result. The controllers were purchased at a major retailer (Best Buy), so they should be from a large maker, and of good quality.   I have never used either PS3 or XBOX controllers before, but the instructions given on the recalbox site seem very straightforward and easy to follow. I have not changed any configuration settings other than the ones mentioned above in the recalbox installation.   Forgot to mention I also attempted recalbox installation on two different microSD cards from different makers just in case that was the issue.  No difference. Are the any diagnostics I can run to gather further information. Thanks very much for any help you can provide.  Your assistance is greatly appreciated! All the best, Mark
            did you associated xbox dongle with gamepads ? you have sync buttons on each, press them and wait any secondes
            • mlookabaugh
              I am ashamed to post this, but you deserve a follow up.  The batteries were inserted incorrectly in the XBOX controller.  In my defense, they have the little "springs" both on one side, which almost always indicates that the flat (negative) side goes there.  Of course, there was also a diagram printed on the battery pack which showed the correct orientation, but let's not talk about that.  😉 Never did find out what the problem with the PS3 controller was.  I'm sure it's something equally stupid.  But in any case, as long as I have one controller working, I should be good to go. Thanks very much for your assistance.  🙂 Mark
              • davmanypsp
                davmanypsp last edited by
                Hi, you can also try to reset the Dualshock 3 and try again the pairing process.
                • civilchaos
                  civilchaos last edited by
                  Hi, I have the same problem with official DS3 controller, and have no other controllers to fall back on. I actually have two DS3 controllers (one black and one silver) neither work. Here is the output from the dmesg command:
                  [root@RECALBOX ~]# dmesg [    0.000000] Booting Linux on physical CPU 0xf00 [    0.000000] Initializing cgroup subsys cpu [    0.000000] Initializing cgroup subsys cpuacct [    0.000000] Linux version 3.19.3-v7 (matthieu@pechuga) (gcc version 4.9.3 (Buildroot 2015.08-git-g9135875-dirty) ) #1 SMP PREEMPT Mon Dec 7 20:19:40 CET 2015 [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [    0.000000] Machine: BCM2709 [    0.000000] cma: Reserved 8 MiB at 0x1e800000 [    0.000000] Memory policy: Data cache writealloc [    0.000000] On node 0 totalpages: 126976 [    0.000000] free_area_init_node: node 0, pgdat 80ac6400, node_mem_map 9e396000 [    0.000000]   Normal zone: 1116 pages used for memmap [    0.000000]   Normal zone: 0 pages reserved [    0.000000]   Normal zone: 126976 pages, LIFO batch:31 [    0.000000] [bcm2709_smp_init_cpus] enter (8640->f3003010) [    0.000000] [bcm2709_smp_init_cpus] ncores=4 [    0.000000] PERCPU: Embedded 11 pages/cpu @9e366000 s12672 r8192 d24192 u45056 [    0.000000] pcpu-alloc: s12672 r8192 d24192 u45056 alloc=11*4096 [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 125860 [    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1872 bcm2708_fb.fbheight=1048 bcm2709.boardrev=0xa01041 bcm2709.serial=0xeca2ef7a smsc95xx.macaddr=B8:27:EB:A2:EF:7A bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.fiq_fix_enable=1 sdhci-bcm2708.sync_after_dma=0 dwc_otg.lpm_enable=0 console=tty3 loglevel=3 elevator=deadline vt.global_cursor_default=0 logo.nologo root=/dev/mmcblk0p6 rootwait [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [    0.000000] Memory: 482768K/507904K available (7920K kernel code, 451K rwdata, 2192K rodata, 484K init, 777K bss, 16944K reserved, 8192K cma-reserved) [    0.000000] Virtual kernel memory layout: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB) [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB) [    0.000000]     vmalloc : 0x9f800000 - 0xff000000   (1528 MB) [    0.000000]     lowmem  : 0x80000000 - 0x9f000000   ( 496 MB) [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB) [    0.000000]       .text : 0x80008000 - 0x809e84f0   (10114 kB) [    0.000000]       .init : 0x809e9000 - 0x80a62000   ( 484 kB) [    0.000000]       .data : 0x80a62000 - 0x80ad2df4   ( 452 kB) [    0.000000]        .bss : 0x80ad2df4 - 0x80b952e4   ( 778 kB) [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [    0.000000] Preemptible hierarchical RCU implementation. [    0.000000] NR_IRQS:608 [    0.000000] Architected cp15 timer(s) running at 19.20MHz (virt). [    0.000014] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns [    0.000037] Switching to timer-based delay loop, resolution 52ns [    0.000322] Console: colour dummy device 80x30 [    0.000546] console [tty3] enabled [    0.000578] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000) [    0.000605] pid_max: default: 32768 minimum: 301 [    0.001037] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [    0.001059] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [    0.002363] Initializing cgroup subsys memory [    0.002417] Initializing cgroup subsys devices [    0.002447] Initializing cgroup subsys freezer [    0.002487] Initializing cgroup subsys blkio [    0.002580] CPU: Testing write buffer coherency: ok [    0.002666] ftrace: allocating 25272 entries in 75 pages [    0.065380] missing device node for CPU 0 [    0.065419] missing device node for CPU 1 [    0.065431] missing device node for CPU 2 [    0.065443] missing device node for CPU 3 [    0.065464] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00 [    0.065481] [bcm2709_smp_prepare_cpus] enter [    0.065627] Setting up static identity map for 0x72e9c0 - 0x72ea18 [    0.125396] [bcm2709_boot_secondary] cpu:1 started (0) 17 [    0.125779] [bcm2709_secondary_init] enter cpu:1 [    0.125841] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01 [    0.145356] [bcm2709_boot_secondary] cpu:2 started (0) 18 [    0.145677] [bcm2709_secondary_init] enter cpu:2 [    0.145715] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02 [    0.165436] [bcm2709_boot_secondary] cpu:3 started (0) 17 [    0.165679] [bcm2709_secondary_init] enter cpu:3 [    0.165718] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03 [    0.165818] Brought up 4 CPUs [    0.165846] SMP: Total of 4 processors activated (153.60 BogoMIPS). [    0.165858] CPU: All CPU(s) started in SVC mode. [    0.166886] devtmpfs: initialized [    0.186961] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [    0.188429] pinctrl core: initialized pinctrl subsystem [    0.188977] regulator-dummy: no parameters [    0.189662] NET: Registered protocol family 16 [    0.195559] DMA: preallocated 4096 KiB pool for atomic coherent allocations [    0.225209] cpuidle: using governor ladder [    0.255238] cpuidle: using governor menu [    0.255819] bcm2709.uart_clock = 3000000 [    0.255864] of_platform_populate failed: -22 [    0.258447] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [    0.258464] hw-breakpoint: maximum watchpoint size is 8 bytes. [    0.258505] mailbox: Broadcom VideoCore Mailbox driver [    0.258607] bcm2708_vcio: mailbox at f300b880 [    0.258988] bcm_power: Broadcom power driver [    0.259006] bcm_power_open() -> 0 [    0.259018] bcm_power_request(0, 😎 [    0.759684] bcm_mailbox_read -> 00000080, 0 [    0.759698] bcm_power_request -> 0 [    0.759838] Serial: AMBA PL011 UART driver [    0.759973] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3 [    0.838320] SCSI subsystem initialized [    0.838774] usbcore: registered new interface driver usbfs [    0.838885] usbcore: registered new interface driver hub [    0.839040] usbcore: registered new device driver usb [    0.839725] Advanced Linux Sound Architecture Driver Initialized. [    0.840656] Bluetooth: Core ver 2.20 [    0.840724] NET: Registered protocol family 31 [    0.840738] Bluetooth: HCI device and connection manager initialized [    0.840762] Bluetooth: HCI socket layer initialized [    0.840782] Bluetooth: L2CAP socket layer initialized [    0.840874] Bluetooth: SCO socket layer initialized [    0.841504] cfg80211: Calling CRDA to update world regulatory domain [    0.842730] Switched to clocksource arch_sys_counter [    0.882902] FS-Cache: Loaded [    0.883282] CacheFiles: Loaded [    0.898595] NET: Registered protocol family 2 [    0.899758] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [    0.899847] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [    0.899953] TCP: Hash tables configured (established 4096 bind 4096) [    0.900031] TCP: reno registered [    0.900055] UDP hash table entries: 256 (order: 1, 8192 bytes) [    0.900097] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [    0.900407] NET: Registered protocol family 1 [    0.900995] RPC: Registered named UNIX socket transport module. [    0.901014] RPC: Registered udp transport module. [    0.901025] RPC: Registered tcp transport module. [    0.901037] RPC: Registered tcp NFSv4.1 backchannel transport module. [    0.901966] bcm2708_dma: DMA manager at f3007000 [    0.902111] bcm2708_gpio: bcm2708_gpio_probe 80a8e718 [    0.902921] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB) [    0.905118] futex hash table entries: 1024 (order: 4, 65536 bytes) [    0.905346] audit: initializing netlink subsys (disabled) [    0.905411] audit: type=2000 audit(0.869:1): initialized [    0.923284] DLM installed [    0.926076] FS-Cache: Netfs 'nfs' registered for caching [    0.927099] NFS: Registering the id_resolver key type [    0.927226] Key type id_resolver registered [    0.927239] Key type id_legacy registered [    0.928222] ntfs: driver 2.1.31 [Flags: R/W]. [    0.929149] fuse init (API version 7.23) [    0.932573] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) [    0.932827] io scheduler noop registered [    0.932855] io scheduler deadline registered (default) [    0.933217] io scheduler cfq registered [    0.934916] BCM2708FB: allocated DMA memory dec00000 [    0.934965] BCM2708FB: allocated DMA channel 0 @ f3007000 [    0.967042] Console: switching to colour frame buffer device 234x65 [    0.988036] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver [    0.988620] uart-pl011 dev:f1: no DMA platform data [    0.989220] vc-cma: Videocore CMA driver [    0.989235] vc-cma: vc_cma_base      = 0x00000000 [    0.989247] vc-cma: vc_cma_size      = 0x00000000 (0 MiB) [    0.989259] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB) [    1.002601] brd: module loaded [    1.009420] loop: module loaded [    1.009797] vchiq: vchiq_init_state: slot_zero = 0x9e800000, is_master = 0 [    1.010713] Loading iSCSI transport class v2.0-870. [    1.011541] usbcore: registered new interface driver cdc_ether [    1.011686] usbcore: registered new interface driver smsc95xx [    1.011760] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [    1.011782] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [    1.011837] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [    1.212205] Core Release: 2.80a [    1.212227] Setting default values for core params [    1.212276] Finished setting default values for core params [    1.412723] Using Buffer DMA mode [    1.412740] Periodic Transfer Interrupt Enhancement - disabled [    1.412752] Multiprocessor Interrupt Enhancement - disabled [    1.412764] OTG VER PARAM: 0, OTG VER FLAG: 0 [    1.412782] Dedicated Tx FIFOs mode [    1.413230] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0x9ec14000 dma = 0xdec14000 len=9024 [    1.413270] FIQ FSM acceleration enabled for : [    1.413270] Non-periodic Split Transactions [    1.413270] Periodic Split Transactions [    1.413270] High-Speed Isochronous Endpoints [    1.413295] dwc_otg: Microframe scheduler enabled [    1.413369] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80476bd4 [    1.413390] WARN::hcd_init_fiq:413: FIQ ASM at 0x80476f44 length 36 [    1.413411] WARN::hcd_init_fiq:438: MPHI regs_base at 0x9f80a000 [    1.413440] dwc_otg bcm2708_usb: DWC OTG Controller [    1.413493] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1 [    1.413546] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000 [    1.413601] Init: Port Power? op_state=1 [    1.413612] Init: Power Port (0) [    1.413968] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [    1.413989] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.414006] usb usb1: Product: DWC OTG Controller [    1.414023] usb usb1: Manufacturer: Linux 3.19.3-v7 dwc_otg_hcd [    1.414039] usb usb1: SerialNumber: bcm2708_usb [    1.415190] hub 1-0:1.0: USB hub found [    1.415260] hub 1-0:1.0: 1 port detected [    1.415987] dwc_otg: FIQ enabled [    1.416002] dwc_otg: NAK holdoff enabled [    1.416013] dwc_otg: FIQ split-transaction FSM enabled [    1.416057] Module dwc_common_port init [    1.416593] mousedev: PS/2 mouse device common for all mice [    1.417814] Bluetooth: Virtual HCI driver ver 1.5 [    1.418060] Bluetooth: HCI UART driver ver 2.2 [    1.418077] Bluetooth: HCI H4 protocol initialized [    1.418089] Bluetooth: HCI BCSP protocol initialized [    1.418100] Bluetooth: HCILL protocol initialized [    1.418111] Bluetooth: HCIATH3K protocol initialized [    1.418122] Bluetooth: HCI Three-wire UART (H5) protocol initialized [    1.418262] usbcore: registered new interface driver bcm203x [    1.418391] usbcore: registered new interface driver bpa10x [    1.418531] usbcore: registered new interface driver bfusb [    1.418669] usbcore: registered new interface driver btusb [    1.418693] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 [    1.418875] usbcore: registered new interface driver ath3k [    1.419152] bcm2835-cpufreq: min=600000 max=900000 [    1.431883] Driver 'mmcblk' needs updating - please use bus_type methods [    1.431942] sdhci: Secure Digital Host Controller Interface driver [    1.431951] sdhci: Copyright(c) Pierre Ossman [    1.432104] mmc-bcm2835 mmc-bcm2835.0: mmc_debug:0 [    1.432117] mmc-bcm2835 mmc-bcm2835.0: DMA channels allocated [    1.462974] sdhci-pltfm: SDHCI platform and OF driver helper [    1.464362] ledtrig-cpu: registered to indicate activity on CPUs [    1.464491] hidraw: raw HID events driver (C) Jiri Kosina [    1.468127] usbcore: registered new interface driver usbhid [    1.468137] usbhid: USB HID core driver [    1.468602] TCP: cubic registered [    1.468619] Initializing XFRM netlink socket [    1.474954] NET: Registered protocol family 10 [    1.479461] sit: IPv6 over IPv4 tunneling driver [    1.480335] NET: Registered protocol family 17 [    1.480514] Bluetooth: RFCOMM TTY layer initialized [    1.480537] Bluetooth: RFCOMM socket layer initialized [    1.480569] Bluetooth: RFCOMM ver 1.11 [    1.480593] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [    1.480609] Bluetooth: HIDP socket layer initialized [    1.481210] sctp: Hash tables configured (established 16384 bind 16384) [    1.481730] Key type dns_resolver registered [    1.482160] Registering SWP/SWPB emulation handler [    1.483060] registered taskstats version 1 [    1.483253] vc-sm: Videocore shared memory driver [    1.483270] [vc_sm_connected_init]: start [    1.483852] [vc_sm_connected_init]: end - returning 0 [    1.486122] ALSA device list: [    1.486138]   #0: bcm2835 ALSA [    1.486809] Waiting for root device /dev/mmcblk0p6... [    1.500204] mmc0: host does not support reading read-only switch, assuming write-enable [    1.502342] mmc0: new high speed SDHC card at address 1234 [    1.502872] mmcblk0: mmc0:1234 SA08G 7.21 GiB [    1.506553]  mmcblk0: p1 p2 < p5 p6 p7 > p3 [    1.593801] EXT4-fs (mmcblk0p6): couldn't mount as ext3 due to feature incompatibilities [    1.594392] EXT4-fs (mmcblk0p6): couldn't mount as ext2 due to feature incompatibilities [    1.612881] Indeed it is in host mode hprt0 = 00021501 [    1.792806] usb 1-1: new high-speed USB device number 2 using dwc_otg [    1.792977] Indeed it is in host mode hprt0 = 00001101 [    1.993043] usb 1-1: New USB device found, idVendor=0424, idProduct=9514 [    1.993060] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [    1.993842] hub 1-1:1.0: USB hub found [    1.993963] hub 1-1:1.0: 5 ports detected [    2.272809] usb 1-1.1: new high-speed USB device number 3 using dwc_otg [    2.373007] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00 [    2.373022] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [    2.375702] smsc95xx v1.0.4 [    2.436147] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:a2:ef:7a [    2.512814] usb 1-1.4: new low-speed USB device number 4 using dwc_otg [    2.758753] usb 1-1.4: New USB device found, idVendor=17ef, idProduct=6018 [    2.758769] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [    2.758781] usb 1-1.4: Product: Lenovo Low Profile USB Keyboard [    2.758792] usb 1-1.4: Manufacturer: Lenovo [    2.814061] input: Lenovo Lenovo Low Profile USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:17EF:6018.0001/input/input0 [    2.873182] hid-generic 0003:17EF:6018.0001: input,hidraw0: USB HID v1.11 Keyboard [Lenovo Lenovo Low Profile USB Keyboard] on usb-bcm2708_usb-1.4/input0 [    2.973708] input: Lenovo Lenovo Low Profile USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:17EF:6018.0002/input/input1 [    3.033290] hid-generic 0003:17EF:6018.0002: input,hidraw1: USB HID v1.11 Device [Lenovo Lenovo Low Profile USB Keyboard] on usb-bcm2708_usb-1.4/input1 [    3.112810] usb 1-1.5: new full-speed USB device number 5 using dwc_otg [    3.234567] usb 1-1.5: New USB device found, idVendor=054c, idProduct=0268 [    3.234584] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [    3.234596] usb 1-1.5: Product: PLAYSTATION(R)3 Controller [    3.234607] usb 1-1.5: Manufacturer: Sony [    3.482805] usb 1-1.2: new full-speed USB device number 6 using dwc_otg [    3.600236] usb 1-1.2: New USB device found, idVendor=2458, idProduct=0001 [    3.600251] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [    3.600263] usb 1-1.2: Product: Low Energy Dongle [    3.600275] usb 1-1.2: Manufacturer: Bluegiga [    3.600285] usb 1-1.2: SerialNumber: 1 [    6.225107] EXT4-fs (mmcblk0p6): recovery complete [    6.228829] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null) [    6.228892] VFS: Mounted root (ext4 filesystem) on device 179:6. [    6.229950] devtmpfs: mounted [    6.230548] Freeing unused kernel memory: 484K (809e9000 - 80a62000) [    6.372603] EXT4-fs (mmcblk0p6): re-mounted. Opts: data=ordered [    6.397747] FAT-fs (mmcblk0p7): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [    6.401495] FAT-fs (mmcblk0p5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [    7.270981] udevd[93]: starting version 3.1.2 [    7.290631] random: udevd urandom read with 120 bits of entropy available [    8.000124] random: nonblocking pool is initialized [   20.594862] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [   20.595100] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [   22.206194] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [   22.207152] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1 [   32.897277] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [   33.005199] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [   34.616265] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
