    Wii U Pro Controller doesn't re-connect after reboot . Recalbox 6.1.1
    GamePad/GPIO/USB encoder
    reboot bluetooth controller pairing
    10
    12
    3367
    • elchhome
      elchhome last edited by elchhome
      Hello Recalbox Team,
      I've just done a fresh installation of Recalbox 6.1.1 on my Raspberry Pi 3 B+.
      In Emulationstation I was able to pair the original Wii U Pro Controller successfully with the internal Bluetooth controller.
      After every reboot the pairing is lost, but the button mapping is still there.
      Pairing the controller again solves the problem until next reboot. That's really exhausting...
      Can you please help me saving the configuration that it survived reboots?
      The bonus question is:
      I have the Retroflag NESPI+ case.
      In the past I've used the safe shutdown script from:
      https://github.com/RetroFlag/retroflag-picase
      Should I use this again or is there already something included with the new Recalbox release?
      Thanks in advance,
      Andi
      1 Reply Last reply Reply Quote 3
      • elchhome
        The wiki mentioned two methods:
        /recalbox/scripts/bluetooth/test-device list
        8C:CD:E8:73:F4:87 Nintendo RVL-CNT-01-UC
        /recalbox/scripts/bluetooth/simple-agent hci0 "8C:CD:E8:73:F4:87"
        Agent registered
        Creating device failed: org.bluez.Error.AlreadyExists: Already Exists
        [bluetooth]# pair 8C:CD:E8:73:F4:87
        Attempting to pair with 8C:CD:E8:73:F4:87
        Failed to pair: org.bluez.Error.AlreadyExists
        [bluetooth]# connect 8C:CD:E8:73:F4:87
        Attempting to connect to 8C:CD:E8:73:F4:87
        [CHG] Device 8C:CD:E8:73:F4:87 Connected: yes
        Connection successful
        [CHG] Device 8C:CD:E8:73:F4:87 ServicesResolved: yes
        [Nintendo RVL-CNT-01-UC]# trust 8C:CD:E8:73:F4:87
        Changing 8C:CD:E8:73:F4:87 trust succeeded
        -> now the controller is connected
        After reboot it can't connect again.
        No progress...
        • Rosch
          Rosch last edited by
          I have the very same problem.
          Wii U Pro Controller and recalbox 6.1.1 on an rpi 3.
          Controller works nice after pairing. No trouble, but pairing is not surviving a reboot.
          After repairing working fine again but this is very annoying because I still have to have keep a USB controller connected.
          Any help appreciated...
          • allanpcsp
            allanpcsp last edited by
            Me too .. same exact problem
            • Rosch
              The problem still persists ...
              Any news on this?
              I tried retropie. There it works but i would love to stick with recalbox
              • ien ien
                ien ien last edited by
                I ve got the same problem with The same controler. Will the next update will fix it? Or do we need to go back to the older version?
                • rsa2000
                  rsa2000 last edited by
                  Same issue, official Wii U Pro. Works great but no longer paired after reboot.
                  • smashingtool
                    smashingtool last edited by
                    Same issue here, driving me nuts.
                    • Sliner
                      Sliner last edited by
                      I have the same issue.
                      Hope for an update or a solution. THX in andvance.
                      Nils
                      • bigheadwillie
                        bigheadwillie last edited by
                        I had the same issue with my 2 official Wii U Pro controllers and found a fix. I changed the line below from =0 to =1 in the recalbox.conf under section D (controllers). After changing this and rebooting my Wii U controllers reconnect every time after a reboot or unplugged power to the recalbox.
                        controllers.bluetooth.ertm=1
                        THe problem is if i change this setting to "1" then my official ps3 controllers no longer reconnect automatically! I am using 2 Wii U pro controllers as my main 2 controllers and 2 ps3 controllers for when i want to play 4 players games.
                        So i have to choose whether i want my wii u controllers or ps3 controlelrs to reconnect to bluetooth after a reboot, i havent found a way to get both to work.
                        • Voytex86
                          Voytex86 last edited by
                          @elchhome I have the same problem with my 8BitDo SN30 pro ("after every reboot the pairing is lost").
                          I think You should open the terminal (press "F4" in Recalbox main menu, then press "ALT+F2", login: root, password: recalboxroot).
                          Then type in "bluetoothctl" then type the following commands :
                          agent on
                          default-agent
                          power on
                          scan on
                          Wait until bluetoothctl lists your device then:
                          pair AA:BB:CC:DD:EE:FF
                          connect AA:BB:CC:DD:EE:FF
                          trust AA:BB:CC:DD:EE:FF
                          Check out this:
                          link 1
                          link 2
                          • Zaphod
                            Zaphod last edited by
                            Minor addition to this
                            Once you go through the normal pairing process you need to make a change so that the controller reconnects.
                            the correct way to do this is to edit /recalbox/share/system/recalbox.cfg and change the follow line(s)
                            Firstly you must change
                            controllers.bluetooth.ertm=0
                            to
                            you may also need to change this
                            controllers.ps3.enabled=1
                            to this
                            controllers.ps3.enabled=0
                            This has been tested with a the official Wii U Pro controller and works flawlessly. I can not attest to how it works with the aftermarket version.
