    Dual boot arch | recalbox
    dual boot arch recalbox
    • bach
      bach last edited by
      Hi,
      I'm new with recalbox but not with linux. i'm trying to installe recalbox in dual boot with archlinux booting with systemd-boot.
      I have a few questions and i wanted to know what you think about it, if it will stand on the long run.
      The box is a vorke v1 with a 64Go ssd and a 500Go hd
      I installed the systems on the ssd, and used the hd as storage for roms
      Partitionning (labels are important) :
      sda (ssd)
      sda1 500M BOOT
      sda2 4G swap
      sda3 20G RECALBOX
      sda4 35G archlinux
      sdb (hd)
      sdb1 500G DATA
      First I installed archlinux as usual, mounting the boot partition in /boot and installing systemd-boot as bootloader (https://wiki.archlinux.org/index.php/Systemd-boot)
      Then i flashed an usbkey with the recalbox x86_64 img, pluged it in the vorke (sdc), and dd the main partition on sda3
      dd if=/dev/sdc2 of=/dev/sda3 bs=4M status="progress"
      Then i mounted the recalbox boot partition, copied bzImage and initrd.gz over to /boot and added an entry on systemd-boot /boot/loader/entries/recalbox.conf
      title recalbox
      linux /bzImage
      initrd /initrd.gz
      options root=UUID=...... rw label=RECALBOX sharewait=30
      and finally i selected DATA as storage through recalbox interface
      my two problems for now :
      1 recalbox don't want to record my hd DATA as storage media, event with sharewait option
      2 boot partition is not mounted on /boot and i can't figure out yet why
      what do you think ?
      • bach
        bach last edited by
        Hi again,
        i solved my probleme, i was coming from my swap partition.
        As explained here, recalbox expect to have 3 partitions : / in the middle, /boot first, and /share last (). So with my swap partition, boot was not mounted and recalbox-boot.conf not available of course.
        So here is my new setup
        sda (ssd)
        sda1 500M BOOT
        sda2 5G RECALBOX
        sda4 55G archlinux
        sdb (hd)
        sdb1 500G SHARE
        the systemd-boot entrie for recalbox
        title recalbox
        linux /bzImage
        initrd /initrd.gz
        options root=UUID=[UUID] rw label=RECALBOX
        and my /boot/recalbox-boot.conf
        sharedevice=DEV [UUID]
        sharewait=30
        every thing is running well now, with no hack at all
