    Video Clips Setup
    Your recalbox
    clips setup
    3648
    • tdelios
      tdelios last edited by
      I installed the latest 6.1.1 Recalbox and I assumed that the video clips for each of my rom games would automatically be there instead of the image art.
      Does anybody have a link to the instructions for me to setup the Video Clips for the games for each console I have?
        paradadf Staff @tdelios last edited by
        @tdelios you need to scrape your roms collection again (with videos), there is no secret.
        tdelios 1 Reply Last reply Reply Quote 0
        • tdelios
          tdelios @paradadf last edited by
          @paradadf which consoles does Video Clips support?
          I ran the scraper against my neo-geo and psx roms and make sure 'use composed visuals' was 'on'.. but after the scraping was completed and I rebooted the raspberry pi, the image art for the games only is displayed and not the Video Clip.
          Is there another setting I need to turn on in order to display the Video Clip and not the image art?
            OyyoDams Staff @tdelios last edited by
            @tdelios Skraper, not internal scraper
            • tdelios
              tdelios @OyyoDams last edited by
              @oyyodams is there a youtube or instructions web on how to perform the video scraps using that software and also give instructions to which folder I should copy the video clips into on the raspberry pi?
                Scavy Global moderator @tdelios last edited by
                @tdelios
                https://www.skraper.net/
                download the latest version. I also recommand you create a screenscraper account to get one more thread for scrapping.
                https://www.screenscraper.fr/
                Screenscraper is the database where all infos, pictures, videos and so on... can be found. Skraper is one of the interface using this database.
                • tdelios
                  tdelios @Scavy last edited by
                  @scavy this is a very good video that explains how to use the skraper:
                  https://www.youtube.com/watch?v=G388Gc6kkRs
                  • tdelios
                    tdelios last edited by tdelios
                    I just wanted to give everyone an update.. I am using a "4TB My Passport Ultra" external USB hard drive and it works with recalbox having the Pi power it directly from the USB port.
                    used the default NTFS partition that came with the drive.
                    I just needed to find a laptop that supported the USB-C port
