    Dragon blaze 6.1 fail to update
    Your recalbox
    dragon blaze 6.1 fail update
    2466
    • DavidK1125
      DavidK1125 last edited by
      Hi guys i am super new to this. After install i tried update but it show an error occured - downloaded. What can i do?
        OyyoDams Staff @DavidK1125 last edited by
        @davidk1125 in this case try a fresh install
        DavidK1125 1 Reply Last reply Reply Quote 0
        • DavidK1125
          DavidK1125 @OyyoDams last edited by
          @oyyodams oh.. Is it means format sd card snd re flash it again?
            @davidk1125 format is not needed, but flash it again will wipe data. That's why we always advice to put roms on external storage
            • DavidK1125
              @oyyodams hi... Tried with 2 new flash.. But the same thing happen...what else can i do?
                @davidk1125 can you describe the issue exactly ? Because with a fresh install, you can't have a download error message!
                • DavidK1125
                  @oyyodams well, tried a few times with new flash. Open donkey kong but it jump out to main menu and need to reset controller again. Tried to update but show the same message as error occurred 0_1574475348980_Screenshot_2019-11-23-10-15-29-36.png 0_1574475388017_Screenshot_2019-11-23-10-15-35-20.png
                    @davidk1125 but why don't you install the LATEST version ? In this case you won't have any upgrade message!
                    • tyrese.donatello
                      tyrese.donatello Banned last edited by OyyoDams
                      I also had this problem, it came from free space on my microsd. there are precautions to take before updating and it is to check if you have enough free space on your microsd or removable media.
