    Scratching fan noise with 6.1.1-Dragonblaze on Odroid XU4
    scratching fan noise
    2101
    • Megamax
      Megamax last edited by Megamax
      Hello, i have installed the new version 6.1.1. on my Odroid XU4
      After a short time i hear a loud scraching noise form the fan, but the fan don't moves.
      With version 6.0 i don't hear anything.
      I think the fan don't get enoth power to move, but make some noise.
      Can i adjust the fan parameters?
      Many thanks for the help!
        OyyoDams Staff @Megamax last edited by
        @megamax hi, please connect to ssh and try this:
        $ mount -o remount,rw / && cd /etc/init.d/ && rm S02fan && wget https://gitlab.com/recalbox/recalbox/raw/master/board/recalbox/xu4/fsoverlay/etc/init.d/S02fan && chmod a+x /etc/init.d/S02fan && reboot
        Megamax 1 Reply Last reply Reply Quote 0
        • IntegRa
          IntegRa last edited by
          Same problem here
          • olivierdroid92
            olivierdroid92 Global moderator @IntegRa last edited by olivierdroid92
            @integra
            Dear all
            On my XU4 I solved the issue with a minimum fan flow running all the time to avoid any bad noise when stopped (idle mode) and try to start up again.
            I will give you all figures details I had modified
              OyyoDams Staff last edited by
              It will be fixed in the next version
              • Megamax
                Megamax @OyyoDams last edited by
                @oyyodams, thanks for the help! Now I hear the normal noise and the fan works correctly! Thank you so much!!
                • olivierdroid92
                  @IntegRa
                  if it can helsp, please find here below my specific XU4 setting to have XU4 fan running all the time according a smooth "curve".
                  May be possible to adjuted depending on your fan builtin quality.
                  Settingof S02fan :
                  Graph :
