    WiFi and SSH Connection issue on XU4 - modified
    wifi ssh connection issue xu4
    1490
    • shs2002
      shs2002 last edited by
      I burned the 6.1.1 version image due to a black screen error in the 6.1.1 update of XU4.
      The 6.1.1 version image that I burned successfully booted.
      But Wi-Fi has a problem. I have two Wi-Fi broadband routers. In recalbox 6.1.1, only one of them is recognized.
      I manually entered my ssid and password to register an unrecognized router, but it didn't work.
      In recalbox 6.1.1, I'm not sure if a weak signal doesn't appear, but in recalbox 6.1, both my routers were recognized.
      I look forward to a quick improvement. Thank you.
        OyyoDams Staff @shs2002 last edited by
        @shs2002 hi,
        Any hidden SSID ? Same SSID on both routers or different SSID configured in recalbox.conf ?
        shs2002 1 Reply Last reply Reply Quote 0
        • shs2002
          shs2002 @OyyoDams last edited by
          @oyyodams
          I have two wifi broadband routers. Each is a rental product of an Internet broadband service provider and the other is a private product.
          Rental products have a strong signal and private products have a weak signal.
          The only difference is that. Private products are not found in the recalbox's list of Wi-Fi routers.
          Thank you.
            @shs2002 which wifi channel is set on "private product" ?
            • shs2002
              @oyyodams private product use CH13 on 2.4GHz.
              Thank you.
                @shs2002 please change the country in recalbox.conf
                For example wifi.region=FR
