    Settings on monitor Sony PVM 14M2U CRT
    settings monitor sony pvm 14m2u
    • DreyMIX
      DreyMIX last edited by
      Hello,
      I can't find the right setting with my Sony PVM 14M2U monitor.
      I have tried various configurations, but the screen is never aligned correctly.
      Currently used:
      • Raspberry Pi 3b
      • Recalbox 18.07.13
      • Gert-VGA VGA666 Adapter Board
      • VGA Male to BNC Male Adapter (5 BNC. 3 RGB + 2 sync H / V)
      This is the configuration in the "config.txt" file:
      disable_splash=1
      disable_overscan=1
      gpu_mem_256=128
      gpu_mem_512=256
      gpu_mem_1024=512
      avoid_safe_mode=1
      kernel=zImage
      overscan_scale=0
      disable_audio_dither=1
      dtparam=audio=on
      dtoverlay=vga666
      enable_dpi_lcd=1
      display_default_lcd=1
      dpi_group=2
      dpi_mode=87
      hdmi_timings=320 1 16 30 34 240 1 2 3 22 0 0 0 60 0 6400000 1
      hdmi_group=2
      hdmi_mode=87
      I believe that the problem is of the "hdmi_timings" line, in fact even with other values taken from the web, I always get unsatisfactory results. But isn't there any way to put the correct values based on my monitor?
      Thx!
      • DreyMIX
        Can anyone help me?
