    [Gpi Case] Cannot add roms
    [gpi case] cannot roms
    • DrJones76
      DrJones76 last edited by
      Hi
      After my installation of recalbox 6.1 on my brand new Gpi case all is fine. At first boot Gpi case is installed and works well.
      Then I attempted to add some roms:
      • using the wifi connection it’s awfully slow (I think it’s normal)
      • So I decided to mount the sd card on my computer using Paragon to access the linux partition. I copied the roms on the dedicated folder, unmouted the card I replaced it in the Case. After the start Recalbox is presenting the non-gpi case interface (with very small characters ). What did happen? There is a way to come back to gpi case interface without reinstalling the system from scratch?
      Is there a way to upload roms through usb cable in the battery cover?
      Thanks
      100.8k
