    Etcher flashing failed
    etcher flashing failed
    • nastinep
      nastinep last edited by
      Downloaded the latest 6.1 build and use Etcher to flash the img file to Raspberry Pi 3. The issue is that the progress bar is stuck on half and never go forward. I am using it on my Macbook Pro
        Scavy Global moderator @nastinep last edited by
        Hi @nastinep
        Did you try an other SD card ? It seems that the one you're using may be corrupted.
        • leaves
          leaves last edited by
          Try other SD card or other burn tools,sometimes Etcher doesn't work.
            etcher with macbook it's not a good friend.
            flash your sd with dd command line.
            • leaves
              leaves last edited by leaves
              Found 2 burners that work on the Macbook Pro.
              https://www.uubyte.com/
              https://softfamous.com/virtual-disk-utility/
