    Recalbox now in reddit
    reddit
    • 8bit_astronaut
      8bit_astronaut last edited by
      Finally a Recalbox sub, please give a try if you want https://www.reddit.com/r/recalbox/
      • reivaax
        reivaax last edited by
        Tank's for your intégration of recalbox on Reddit. May be that can help some gays. But "official" support stay in the forum. It's already difficult to give a good support in only one place... In 2,3,4 place... 😛 But if you have a problem, doesn't hesitate 🙂
        • 8bit_astronaut
          Thanks my friend, everything for recalbox. Its sad that retropie is most known that recalbox
          • digitaLumberjack
            Thank you for the good job you did there pal 🙂
            • 8bit_astronaut
              Since you are the creator of recalbox (i think) we want to make you admin of the subreddit, we sended you an invitation trough reddit
