    Add option in bartop menu
    option bartop
    • diegoarodrigues
      diegoarodrigues last edited by
      Hi, I wonder if can add Controller Configuration on the bartop menu type and how. Ty Sorry for bad english, i used google translate
      Depois escrevo...
      • digitaLumberjack
        Hi, no you cannot. The bartop configuration has been added especially to remove this kind of options. You can activate the default menu to configure your controllers and set back the bartop menu when you have everything configured.
