    My "RaspSNES" (Raspberry inside SNES case)
    Your recalbox
    raspsnes inside snes case
    • rodri
      rodri last edited by
      Some years ago I saw this post: https://www.raspberrypi.org/forums/viewtopic.php?t=36505
      I liked the project very much and I wanted to make a version of it.
      I was able to get a broken SNES (no living console was hurt in this process) and other materials and I have a "1.0 version" of the project.
      Some basic highlights:
      • I setup a recalbox build with gamecon to connect real SNES controllers
      • I used an HDMI cable extension and a SD card extension to have both cables and SD card plugged in the back of the console
      • The power button (safely) shuts down de console
      • The reset button exits games
      • I preferred the Sega Megadrive colors (not Genesis) more than the SNES ones, so an amateur paint job was done
      • I want to move the Pi board to an end, so that I can have a 1.1 version, where I can put a modified SNES cart where I can put USB inputs and maybe some DB9s, that way I can plug a keyboard or extra controllers.
      I put some pictures of the process (I have more) and the "final" product:
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      Hope you like it!
      • cazeysan
        cazeysan last edited by
        Nice ! Good job
        Viens par là, c'est pareil !
