    Save/Load State hotkey differences between platforms [Retroflag GPi 6.1]
    recalbox gpi
    • Tormentor667
      Tormentor667 last edited by
      Dear developers,
      I have bought myself a Retroflag GPi and it works very good with the 6.1 build of Recalbox.
      Unfortunately though I have a problem with hotkey and special functions like load/save state.
      I noticed that not on all platforms, the same key combinations work. For example on SNES I can load/save with hotkey (select) plus x/y but on Gameboy I can only save but not load.
      What can I do here? How can I redefine the hotkey combination? And how can I make the combinations on all platforms the same?
      Best regards
      Dan
      Tormentor667 1 Reply Last reply Reply Quote 0
      • Tormentor667
        Tormentor667 @Tormentor667 last edited by
        Update
        Noticed that things are working when I set up the key-bindings at the beginning in EmuStation but it stops working after rebooting the GPi
