    Switch LED over gpio
    switch led gpio
    • xxxabjxxx
      xxxabjxxx last edited by
      Hello, is there a way to turn a LED on over the gpio on every Start, and LED off when the System shut down? Is it possible to make a command in the recalbox.conf or is there another way?
      • digitaLumberjack
        Hi, you must create your own script and add it to the /etc/init.d/ directory and use the /sys/class gpio spcial files : https://www.raspberrypi.org/forums/viewtopic.php?f=91&t=27830
