    Connection between RPI3 B+ and Windows
    connection between rpi3 windows
    1709
    • Sammy Cohen
      Sammy Cohen last edited by
      Hey, guys. I have a problem with the connection via ethernet cable: When I enter the IP of my Raspberry Pi into the address bar in the browser, then I enter without problems. But when I enter the IP in Windows Explorer, it says that it is impossible to connect. What am I supposed to do ?
      Zing hmichael 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @Sammy Cohen last edited by Zing
        @sammy-cohen Read:
        https://github.com/recalbox/recalbox-os/wiki/Windows-10---cannot-access-Recalbox-from-network-share
        Sammy Cohen 1 Reply Last reply Reply Quote 0
        • Sammy Cohen
          Sammy Cohen @Zing last edited by
          @zing , thanks for answering, but I have Windows 7, instead Windows 10. What should I do in this case ?
          • hmichael
            hmichael @Sammy Cohen last edited by hmichael
            @sammy-cohen To be sur, you type exactly that on your explorer => \\recalbox or \\192.168.XXX.XXX ?
            Sammy Cohen 2 Replies Last reply Reply Quote 0
            • Sammy Cohen
              Sammy Cohen @hmichael last edited by
              @hmichael Yup, but only in the browser the Web interface opens, and through it it is impossible to throw psx ROMs normally. I can't connect through the Explorer. It says "the Resource does not exist" or something like that.
              • Sammy Cohen
                @hmichael , I tried both of these options, but they didn't work
                hmichael 1 Reply Last reply Reply Quote 0
                • hmichael
                  @sammy-cohen
                  It's very strange if you have used double backslash normally windows should show the content of /share.
                  Have you tried to mount your recalbox as a "network drive" on your PC?
                  The access problem is only on the recalbox or is it general?
                  If you try to another PC that offers a samba share you can access it?
