    I can’t assign gamepad buttons for Nintendo 64.
    can’t assign gamepad buttons nintendo
    • Snaider
      Snaider last edited by Snaider
      Hello. The problem is that I can not assign buttons to the Nintendo 64 controller for this instruction (github.com/recalbox/recalbox-os/wiki/Configure-N64-controllers-(EN)).
      I edited the file "InputAutoCfg.ini" and "mupen64plus.cfg". After starting the game Nintendo 64 - settings are reset again by default.
      The instructions say that the "/mupen64plus" section is read-only. I use the "mount -o remount, rw /" command before editing the files, but they are all the same reset by default after starting the games or rebooting.
      Tell me what I'm doing wrong?
      I did not expect to encounter such a problematic setting.
      I am using rasberi pi3 b + and RecalBox 6.0
      • flaker38
        flaker38 last edited by
        Hello
        You should edit the /recalbox/share/system/recalbox.conf file and add a line with :
        n64.configfile=dummy
        Your configuration file will not be reset.
        This info comes from https://forum.recalbox.com/topic/9016/a-lire-manettes-n64
        Wiki should be updated.
        Odroid XU4Q + Boitier OGST
        Snaider 1 Reply Last reply Reply Quote 0
        • Snaider
          Snaider @flaker38 last edited by
          @flaker38 Thank you. Everything worked out. Did according to your advice. Now I play like a real Nintendo 64!
