    Want to disable wifi encryption on Recalbox x86_64
    disable wifi encryption recalbox x8664
    • jimsicle
      jimsicle last edited by
      When I connect to wifi on Recalbox (Dragonblaze) I've not had much success with staying connected after the machine reboots.
      I know the wifi password gets encrypted after a reboot but it always appears offline after that.
      I've edited the config file to match my wifi password but it never works. Can anyone give me any pointers?
      Thanks all!
      • jimsicle
        I just saw that not only has this issue been posted already, but apparently this is a known issue with x86_64 builds and the devs are looking into it.
        Sorry about this and again keep up the amazing work that you do for this OS!
