    WiFi problem (RecalBox PC)
    wifi recalbox
    • PrincessJakey
      PrincessJakey last edited by
      Hello I’m running RecalBox PC I can’t seem to get it to connect to my WiFi I entered my SSID & PASSWORD but it still says not connected, I also tried entering details in the recalbox.config file same situation tho.
      I have tried searching the forums I can’t seem to find the right answer or its in another language.
      Any and all help appreciated, loving my arcade machine I built so far thank you recalbox!
      FlowerJakey
      BernoO 1 Reply Last reply Reply Quote 0
      • BernoO
        BernoO @PrincessJakey last edited by BernoO
        @princessjakey It's a fresh install of dragonblaze? The team is aware of this issue. All we have to do is wait for the problem being repaired and do beta testing. As long as i know, this issue is only on x86-x64 machines. So, stay tuned and check every often about this (as i do every week :D)
        https://gitlab.com/recalbox/recalbox/issues/565
        Cheers!
        Edit: by the way, with eth0 works pretty well, try that for now.
        • PrincessJakey
          @bernoo thank you very much for the clarification, been spending hours troubleshooting my machine, it’s nice to know it’s a known bug not just me or something wrong with my machine!
          I will definitely give an Ethernet cable a try!
          Thank you again very very much!
          FlowerJakey
          • PashaSan
            PashaSan last edited by PashaSan
            Hi there!
            Recalbox box ver 6.0-Dragonblaze, RPi 3 B+
            I have a problem with my wifi. My hot spot have hidden SSID. I still without network connection after entering ssid and key, and switching WiFi switch on in network menu. I checked ssid and key in recalbox-backup.conf. They are correct.
            How can I get a link to the Inet by WiFi.
            Sanx
