    Bluetooth dongle problem
    Your recalbox
    bluetooth dongle
    • tiagoko
      tiagoko last edited by tiagoko
      Hi,
      I have raspberry 3 pi b+ and recalbox 6.0 installed, but my bluetooth dongle not recognize. I want to pair my ps3 controllers at dongle because of the big delay.
      My dongle is a Chipset: CSR8510 and 4.0 version.
      Here, some comands and results at terminal:
      hciconfig -a
      hci1: Type: Primary Bus: UART
      BD Address: B8:27:EB:7A:20:DB ACL MTU: 1021:8 SCO MTU: 64:1
      UP RUNNING
      RX bytes:1018 acl:0 sco:0 events:48 errors:0
      TX bytes:2248 acl:0 sco:0 commands:48 errors:0
      Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
      Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
      Link policy: RSWITCH SNIFF
      Link mode: SLAVE ACCEPT
      Class: 0x000000
      Service Classes: Unspecified
      Device Class: Miscellaneous,
      HCI Version: 4.1 (0x7) Revision: 0xb6
      LMP Version: 4.1 (0x7) Subversion: 0x2209
      Manufacturer: Broadcom Corporation (15)
      hci0: Type: Primary Bus: USB
      BD Address: 00:1A:7D:DA:71:11 ACL MTU: 679:9 SCO MTU: 48:16
      DOWN
      RX bytes:1722 acl:0 sco:0 events:90 errors:0
      TX bytes:1104 acl:0 sco:0 commands:90 errors:0
      Features: 0xff 0xff 0xcd 0xfa 0xdb 0xbf 0x7b 0x87
      Link policy: RSWITCH HOLD SNIFF PARK
      hciconfig hci0 up
      Can't init device hci0: Operation not supported (95)
      dmesg | grep too
      [ 4.634606] Bluetooth: Core ver 2.22
      [ 4.634773] Bluetooth: HCI device and connection manager initialized
      [ 4.634798] Bluetooth: HCI socket layer initialized
      [ 4.634812] Bluetooth: L2CAP socket layer initialized
      [ 4.634849] Bluetooth: SCO socket layer initialized
      [ 11.869152] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [ 11.869164] Bluetooth: BNEP filters: protocol multicast
      [ 11.869183] Bluetooth: BNEP socket layer initialized
      [ 16.332505] Bluetooth: HCI UART driver ver 2.3
      [ 16.332519] Bluetooth: HCI UART protocol H4 registered
      [ 16.332525] Bluetooth: HCI UART protocol Three-wire (H5) registered
      [ 16.333372] Bluetooth: HCI UART protocol Broadcom registered
      Can somebody help me ? Thanks
        paradadf Staff @tiagoko last edited by
        @tiagoko how are you trying to pair your controller?
        And why a bluetooth dongle with the rpi3b+? Imo, it works pretty well with the internal.
        • tiagoko
          Hi @paradadf ,
          It's because of the delay comands.
          Let's me explain:
          When i press a Button, i have noted a delay to game response. It's not ocorred when i connected the controller at USB cable.
          i pair the controller connecting the cable USB, then i wait for 10 seconds and remove the cable. Few seconds after, the controler is paired. This don't connected when i plug bluetooth dongle, Just with internal Bt.
          sorry my english.
            @tiagoko I don‘t have the delay on the pi3b+, but only on the 3b. But ok. Why do you say your dongle isn‘t recognized? It appears to me it is working properly.
            • tiagoko
              Not appear the Manufacturer from bluetooth dongle, so i think that i need install a driver to be recognized.
              When i tryied to start USB Bluetooth with comand hciconfig hci1 up, says that operation is not permited.
              And when i connect the dongle, the controller not pair with it.
              Do you know How configure and start Bluetooth?
              Thanks
