    Batocera 5.2 PI3 ROMs don't Load.
    Emulator Arcade/PC/Console
    batocera 5.2 pi3 roms dont
    • kraimax
      kraimax last edited by
      Hello,
      So, i bought a raspberry kit with an already preinstalled sistem with lots of roms, was suposed to be plug and play, but it didnt work. Since im not completelly stupid in informatics tried to fix it, but ultimatelly i f**ked the system. So i downloaded batocera recalbox, installed it correctly as any guide on the internet says, and the same problem persists.
      So, what happens?
      The system opens normally, but no roms, not even the ones that come with the system to test work. When i select it the screen goes black, and my TV shows a message that theres nothing connected to the HDMI port.
      The little LEDs on the raspberry shows as follows: One red permanently lit. One green intermitent. No sound comes out and i can't reset the "console" with the joystick.
      Im downloading another distribution to try it on, but i would like it to work with this one. Can anyone tell me what could be the issue?
      • ian57
        ian57 Staff last edited by
        Sorry we don't make the support for Batocera. Please ask on their forum.
