    6.0 DragonBlaze SSH 'connection closed'.
    6.0 dragonblaze ssh connection closed
    • CroweS
      CroweS last edited by
      Hi folks,
      I've deployed the current (6.0-DragonBlaze Build 193955549) image onto a Pi3. I'm unable to connect to it via ssh for some reason. When I ssh -v I get this.....
      C:>ssh -v root@192.168.2.172
      OpenSSH_for_Windows_7.6p1, LibreSSL 2.6.4
      debug1: Connecting to 192.168.2.172 [192.168.2.172] port 22.
      debug1: Connection established.
      debug1: key_load_public: No such file or directory
      debug1: identity file C:\Users\steve/.ssh/id_rsa type -1
      debug1: identity file C:\Users\steve/.ssh/id_rsa-cert type -1
      debug1: identity file C:\Users\steve/.ssh/id_dsa type -1
      debug1: identity file C:\Users\steve/.ssh/id_dsa-cert type -1
      debug1: identity file C:\Users\steve/.ssh/id_ecdsa type -1
      debug1: identity file C:\Users\steve/.ssh/id_ecdsa-cert type -1
      debug1: identity file C:\Users\steve/.ssh/id_ed25519 type -1
      debug1: identity file C:\Users\steve/.ssh/id_ed25519-cert type -1
      debug1: Local version string SSH-2.0-OpenSSH_for_Windows_7.6
      debug1: Remote protocol version 2.0, remote software version dropbear_2017.75
      debug1: no match: dropbear_2017.75
      debug1: Authenticating to 192.168.2.172:22 as 'root'
      debug1: SSH2_MSG_KEXINIT sent
      debug1: SSH2_MSG_KEXINIT received
      debug1: kex: algorithm: curve25519-sha256@libssh.org
      debug1: kex: host key algorithm: ecdsa-sha2-nistp521
      debug1: kex: server->client cipher: aes128-ctr MAC: hmac-sha2-256 compression: none
      debug1: kex: client->server cipher: aes128-ctr MAC: hmac-sha2-256 compression: none
      debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
      Connection closed by 192.168.2.172 port 22
      I'm keen to connect using Putty to work out why I can't get the Amiga emulator to work 🙂
      Any help more gratefully received.
      Steve C.
        OyyoDams Staff @CroweS last edited by
        @crowes did ou have a previous installation of Recalbox ? Do you have an external storage ?
        CroweS 1 Reply Last reply Reply Quote 0
        • CroweS
          CroweS @OyyoDams last edited by
          @oyyodams - I did have the 2018.12.24 Christmas.Beta release on that Pi3 (and remains available on another SD card). There is indeed an external (32Gb USB) storage device that is connected to the Pi containing ROMs.
            @crowes so you may have an old ssh configuration on your computer. SSH keys have changed on Recalbox side, so you have to clean up your SSH keys on your computer.
            • CroweS
              Thank you for the suggestion. I've tried all I can to remove existing keys. Do Putty, WinSCP and OpenSSH (Win 10) all keep the local key info in the same place (I'm doubtful)? I'm having the same problem despite my efforts (mostly with a fair bit of Google help).
              Any further guidance would be most appreciated. I'm no expert on SSH, however I'm a quick learner. 🙂
              Rgds, Steve.
              101.4k
