    API problem
    api
    • gabylan12
      gabylan12 last edited by
      I have enabled the api in recalbox.conf. system.api.enabled=1
      But when i try the api did not work
      curl localhost:1337
      curl: (7) Failed to connect to localhost port 1337: Connection refused
      my version is 6.0-DragonBlaze
        OyyoDams Staff @gabylan12 last edited by
        @gabylan12 Hi,
        API doesn't work anymore and needs to be rewritten.
        Regards
